View Full Version : Any xB owner with HIDs?
ckk81 05-26-2004, 05:07 AM what temp. do you have?
how did you mount the ballast(spelling)?
how much and where did you get it?
post some pics with HIDs and under the hood work.....
thanks,
Jack
BlueScionXB 05-26-2004, 05:12 AM Hector (toyotaisme) has the HID's on his box...and they look pretty pimp.
I just can't bring myself to spend $400+ on lights...
ckk81 05-26-2004, 05:29 AM Hector (toyotaisme) has the HID's on his box...and they look pretty pimp.
:D thanks for the quick reply..........
i was thinking the same way when i first got my jetta...........but
after i start driving my IS300 and M3 at night...........WOW....i just can't go back
its like" i had been with 56k for long time but once i install cable modem.....it was impossible to go back to 56k........never"
:twisted: kinda the same concepts with the halogen(spellings) and HIDs....
TKBLAZER 05-26-2004, 05:35 AM hids are great, i don't have a scion yet but when i do i'll have hids for sure... night and day difference between regular halogens and hids
quadoptix 05-26-2004, 05:35 AM i do...my bulbs r 5K bulbs...umm i mounted the ballast on a flat spot in the engine bay by the headlight and tucked the wires in the fender, and the brand i had were gourmet garage hid's which r no longer in production. i can get a couple other brands at this moment. ill pm u back when i find out.
ckk81 05-26-2004, 05:42 AM i do...my bulbs r 5K bulbs...umm i mounted the ballast on a flat spot in the engine bay by the headlight and tucked the wires in the fender, and the brand i had were gourmet garage hid's which r no longer in production. i can get a couple other brands at this moment. ill pm u back when i find out.
is it possible for you to get some pics with the hids on.............. & how the set up looks like under the hood?
thanks,
Jack :D
If you do a search for HID's you'll find a ton of stuff. There's been quite a few discussions on this. Plus there are a couple pictures that you can check out. :)
ckk81 05-26-2004, 03:37 PM If you do a search for HID's you'll find a ton of stuff. There's been quite a few discussions on this. Plus there are a couple pictures that you can check out. :)
i did a few search.........but end up just pics of Hids at night shots. i want some under the hood setup........such as mounting etc......... :D
wyldkard 05-26-2004, 04:14 PM OBZ: I like your new riddle, but it's actually a trick, there are lots of different answers.
Such as: prince, care, deadline, posse, needle, brass...I can think of a few others.
:D
-Z
JDMxB 05-26-2004, 04:26 PM All you have to do for mounting is to just secure the two ballasts on the R/L sides of the car...should be right over the R/L wheel well.
And for those who claim that 300+ for "lights" is rediculous--you probably have never driven a car equipped with HIDs. Also--can you really put a price on improved road vision at night? Makes you think about all those useless mods that add up to more than a few hundred bucks, don't it.
The_Bilingual_Gringo 05-26-2004, 05:08 PM And for those who claim that 300+ for "lights" is rediculous--you probably have never driven a car equipped with HIDs. Also--can you really put a price on improved road vision at night? Makes you think about all those useless mods that add up to more than a few hundred bucks, don't it.
Truth
I put them on my Corrado and after driving with HID's for like 2 years, I can't go back to regular lights. After rock guarding the front, it'll be the first purchase I make on mine.
xboxPS2 05-26-2004, 05:46 PM soo ya, where can i pick up some hid's and what's so hard about the install? someone enlighten me por favor
Jeff
ecandlcubed 06-02-2004, 11:56 AM with the hid conversion, does it take away the hi beam capability since xb uses same bulb for both functions?
ShadowMage 06-02-2004, 01:39 PM with the hid conversion, does it take away the hi beam capability since xb uses same bulb for both functions?
Yep! That's one of my big apprehensions with doing this conversion. But I may bite the bullet when the time comes. ;)
JDMxB 06-02-2004, 05:11 PM with the hid conversion, does it take away the hi beam capability since xb uses same bulb for both functions?
Not if you buy a kit that features a Hi/Lo beam function...
These typically cost more, but do feature a mechanism that directs the light upwards when you hit the hibeams.
