245/35-19 on a 8 inch rim?
Old Apr 1, 2006 | 06:39 AM
Kilo6_one's Avatar
Default 245/35-19 on a 8 inch rim?
this is not for the Tc, but im curious if its possible/ ok to run a 245/35 on a 19x8 wide rim?
Old Apr 1, 2006 | 09:36 PM
ack154's Avatar
I think it would... I think a 245 tire will fit on 8-9.5" width. That's according to the tire size calculator on 1010tires.com.
Old Apr 1, 2006 | 10:40 PM
Kilo6_one's Avatar
ill have to check that link, thanks......
i have 235's now and they still look anemic........
Old Apr 3, 2006 | 01:28 PM
toyota_scion_tc's Avatar
It will.
Old Apr 3, 2006 | 05:27 PM
Kilo6_one's Avatar
will it stick out too much over the lip? that is fine if it does its going my wifes car, so hopefully it will protect the rim from the curbs that jump out of nowhere supposedly
Old Feb 24, 2007 | 12:32 AM
vansterdam's Avatar
I don't think you'd have any problems fitting a 245/35R19 on a 8 inch wide rim. I check that tire calculator and it says the recommended rim width range is 8 to 9.5 inches.
Old Feb 27, 2007 | 08:09 AM
MPanova's Avatar
I have 255-30 on my 8.5's and they are perfectly fluch with the lip of the wheel. so in theary 10mm less width in the tire and 12.7mm less width in the wheel should still be about the same as mine
Old Feb 27, 2007 | 03:37 PM
Kilo6_one's Avatar
it fits but does not look very good, i tried that back when i had my TC, it ended up looking bloated. so i would not recomend it, the widest i would do is a 235/35 on a 8" wide rim.
rvascion
Nov 12, 2020 03:23 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
