Im looking for cosmetics mainly here but the performance aspect wont bother me ;)
So far the Wilwood and Stoptechs are the only thing I have seen, both are just front bbk's and both equally costly.
Any help is love.
krdshrk
04-02-2006, 02:59 PM
Dezod sells the Stoptech stage 2 kit - rotors and pads and brake lines.... Uses the stock calipers but it looks a lot better.
Neothin
04-03-2006, 02:17 AM
check out the powerslot plus kit. it incorporates a larger slotted rotor with the stock caliper. with new brake pads, that kit, and some SS lines, you'll have a nice looking kit that reduces stopping distances.
Kilo6_one
04-03-2006, 02:23 AM
i got the powerslot plus kit for the fronts, now im looking to do the rear. the fronts cost me 500.00 shipped, and the rears are about 250.00.......
i am using the stock caliper with axxis pads and ss lines, and i would say it looks great, and stops just as well
aitrus
04-03-2006, 05:52 AM
Can any of you guys host a pic for me. I wanna do the fronts and rears. Since Im looking for more cosmetic over performance it seems odd to have the front only done.
Thanks
Joe_Dezod
04-03-2006, 05:58 AM
Yes we do sell all of the brake lines from each company.
I currently use Brembo cross-drilled brakes for the front and rear, with Axxis ultimate pads. Great combination.
Here's a link so you may look at what we have to offer for your tC...
Stoptech Stage 2: $569 complete (we're one of two authorized dealers for the Stoptech line, excluding their big brake kit).
http://www.dezod.com/pd_stoptech.cfm
Click here and look for our custom packages. They include power slot rotors, and pads (either Axxis Delux, Axxis Ultimate, or EBC greenstuffs). Prices range from $402-$489.
http://www.dezod.com/cat_dezod.cfm
Here's a wide selection for rotors for the Scion tC...
http://www.dezod.com/cat_scion_rotors.cfm
Please email Sales@Dezod.com for pricing on brake pads sold seperately from the rotors. That part of the site is under construction and we are adding more things to it. We sell Axxis, EBC, Hawk, and more...
Kilo6_one
04-03-2006, 06:39 AM
powerslot 12.8" big brake conversion behind my 19" rims
http://i9.photobucket.com/albums/a86/kwb977/IMG_15271.jpg
mwuf15
04-03-2006, 08:32 AM
did u use the stock calipers?
Kilo6_one
04-03-2006, 08:39 AM
yes, that is how the kit works, you use the stock calipers and they give you a bracket to relocate them so you can get a bigger rotor on the car
Neothin
04-03-2006, 06:37 PM
where are you finding the front and rear kit for that cheap?
chibo
04-04-2006, 03:49 AM
Would anyone happen to have pictures or dimensions of the rotors and adapters used in the powerslot kit? I think it would be a lot cheaper to pick the rotors up off another car with the same bolt pattern and size and then fab my own brackets.
Shouldn't be had to find brembo blank rotors in 5x100 bolt pattern with a 54.1 center bore... now that I think about it I don't even need dimensions. Ah, planning begins.
10.8" up front, 10.6" up front stock.....
Kilo6_one
04-04-2006, 07:13 AM
there was a guy on Ebay selling them, and i offered him 500.00 and he took it.......
good luck making your own kit.......
the rotors are 12.8" do the math 12.8-10.8 = 2 inches, you you need to fabricate a bracket that will set the caliper out 2 inches. however check the thickness of the rotor your going to use, it may be thicker or thinner then the stock rotor, or the PS rotor making for a issue of fittiment. talk to "the instigator" he knows about brakes.
chibo
04-04-2006, 09:51 PM
the rotors are 12.8" do the math 12.8-10.8 = 2 inches, you you need to fabricate a bracket that will set the caliper out 2 inches. however check the thickness of the rotor your going to use, it may be thicker or thinner then the stock rotor, or the PS rotor making for a issue of fittiment. talk to "the instigator" he knows about brakes.It would be moved one inch, not two... Looking into it, I don't own a TC, my girlfriend does and I feel like messing with it :lalala:
retrodrive
04-04-2006, 10:35 PM
Increasing rotor size without changing the caliper seems pretty usless to me. You sacrafice acceleration, braking power and increase service costs
Kilo6_one
04-05-2006, 12:19 AM
your right its one inch i went out and measured the bracket....i suck at math i guess.
as for increasing service cost, what do you mean?
not that i care if it costs more, but im curious. as for braking power, it stops better then it did stock so that is all i can ask for... and that is point right, to stop better?
chibo
04-05-2006, 03:27 AM
Increasing rotor size without changing the caliper seems pretty usless to me. You sacrafice acceleration, braking power and increase service costsTrue it increases unsprung weight and the rotors are more expensive, but braking power is increased since you are moving the braking pressure further out.
Kilo6_one
04-05-2006, 05:11 AM
i knew about the unsprung weight, im running 19's so i can use all the help i can get.....
from talking to "the instigator" this kit fit my needs, i dont track my car or race it, i just was looking for something to help with the mushy stock set up. I looked at the Stoptech BBK and the endless kit as well, but it was overkill.
