My new wheels!
Old Apr 6, 2006 | 11:04 PM
buzzwyzr's Avatar
Default My new wheels!
06.5 BOP on Nexo M20 18x7.5 ET +40 with OTG rear shims
I know, I know, it needs a bath BAD! As soon as Katrina-West passes through NorCal for good, I'll get her all nice and shiny!!
And yes, she's getting the Tein/Koni treatment next month too.
Here are the center caps I made.
Old Apr 7, 2006 | 02:15 AM
corlissb's Avatar
How did you make those center caps? It looks great having custom wheels with Scion caps...
Old Apr 7, 2006 | 03:53 AM
buzzwyzr's Avatar
Here's what I did.
*First, I removed the Scion emblems from the stock hub caps. I did this by using a small flathead screwdriver to break the mounting tabs for the emblem on the back of the hub cap. Just pry and they come right off!
*Next, I had to remove what was left of the mounting tabs on the back of the emblems. I did this by using a razor blade to cut as much of the tab off as I could. The plastic is surprisingly soft, so a fresh, sharp razor blade worked really well. Once I cut the tabs down as far as I could, I got some fairly gritty (like 250 or 300 grit) sandpaper and smoothed what was left of the tabs, leaving the back of the emblems as flat as possible.
*I then had to prep and paint the Nexo center cap "insert" (the little tin-like sticker they give you to put in the center cap). This winds up being the black border that surrounds the Scion emblems. I sanded the insert until the surface was fairly grainy, the primed it with a zinc-based primer from an aerosol can. After the primer dried, I gave it another primer coat and allowed that one to dry as well. I then painted the insert satin black (from an aerosol can as well) and allowed it to dry. I then gave the insert two more coats.
*Once the inserts dried, I used just a little bit of two-part epoxy on the back of the emblems to hold them to the inserts. This assured they wouldn't move while I was putting the clear acrylic over them.
*Once I got the placement of the emblem right where I wanted it, I peeled off the adhesive cover from the back of the inserts, then stuck it inside the center cap.
*I then used a product called Super-Glo. It's a two-part hard acrylic that fries super-clear and super-glossy. You basically mix equal parts of the hardener and resin that come in the kit, then pour it into the mold. In this particular case, the mold was the inside of the center cap. The center cap is about 4-5mm deep, so it made a nice little "cup" for the acrylic. I didn't wanna just pour the acrylic over the cap because I was afraid it would go everyewhere, even places I didn't want it to! So i used a medicine dropper to put a little bit at a time into the cap until I got the thickness of the acrylic just right. This particular product takes 36 hours to cure completely.
*After the coating cured, I cleaned them up with some glass cleaner and a microfiber towel, and voila! There you have it.
I really wish I had taken pictures of the whole process, but I didn't think of doing that until I was finished with the project. Hope this helps.[/list]
Old Apr 7, 2006 | 06:08 AM
Boxer_Rebellion's Avatar
Nice work!
Old Apr 7, 2006 | 06:59 AM
Psyco565's Avatar
Hey this should be in the Tech section!! Someone get a Super mod to move it there
Old Apr 9, 2006 | 07:03 PM
ScionChe's Avatar
Awesome! The center-caps you made look great!
Old Apr 9, 2006 | 07:06 PM
AstroJR's Avatar
sickkk bump bump bump
Old Apr 9, 2006 | 07:18 PM
cjastacio's Avatar
Those center caps are PHAT! I will have to give that a try on the wheels I get. Actually those were on my list of choices for wheels, they look great!
Old Apr 9, 2006 | 11:59 PM
Sciond's Avatar
nice job...
Old Apr 10, 2006 | 03:36 PM
buzzwyzr's Avatar
Thanks for all the kind words.
Old Apr 11, 2006 | 09:39 AM
chokeebb21's Avatar
Nice...
Old Apr 11, 2006 | 09:51 AM
HoTBoX009's Avatar
I have to admit, you did an awesome job on those caps!
Looks very professional.
Old Apr 15, 2006 | 04:41 PM
slickyricky102's Avatar
good job on the caps
Old Apr 23, 2006 | 09:56 PM
PrettyniceB's Avatar
Old Apr 24, 2006 | 12:16 AM
keoki's Avatar
looks good mang! another sweet bop!!!!!!!!!!!
Old Apr 24, 2006 | 06:20 PM
Soon2HaveAbox's Avatar
Nice touch with the center caps. Looks good.
Old Apr 30, 2006 | 06:29 PM
TequilaBox's Avatar
Awesome work with the center caps man! Bloody brilliant!
Old Apr 30, 2006 | 09:44 PM
wanna_bB's Avatar
Great job on the center caps!
Just lower the box now
Old May 1, 2006 | 05:25 AM
hxckid88's Avatar
Seriously! Those are awesome. I definately want to do that! TECH SECTION! =P
Old Jun 14, 2006 | 04:36 AM
beevdawg's Avatar
i just might have to do that to my rims, very nice.
