XB replacement Dash..
Old Apr 7, 2006 | 11:58 PM
soypablo's Avatar
Default XB replacement Dash..
Does anyone kow where I could buy a replacement dash piece? I have searched for it and all I come up with are dash accent kits..I need the whole thing. I tried to paint mine and I think that the platic is contaminated in two spots. I have resanded and resanded and used real good adhesion promoter. all my other pieces seemed to work fine....I kind of want to avoid the dealerships just because they are priced very high...
Thanks for your help..
Old Apr 8, 2006 | 12:01 AM
cherryBox's Avatar
either gonna be top-of-the-line or bottom-of-the-barrel (stealership or junkyard)
why don't you glass it?
Old Apr 8, 2006 | 12:07 AM
tyrantcold's Avatar
Before you can get any paint to bond to a plastic like what the dash is made of not only do you need to sand it you need to PRIME it. use a plastic primer like Mathews Ti-coat and then another primer a base and then a clear coat .
also before painted clean the surface with denatured alcohol.
Old Apr 8, 2006 | 06:32 PM
soypablo's Avatar
THanks for the info, I used both primer and adhesion promoter. It worked great on everything but that dash piece.. And it was only two spots on the part that were bad. I cleaned it too, with wax and grease remover, I also used fusion paint. Well that is what I used on all the other pieces the dash piece is still in primer I am giving it time to kick and make sure it is set before I break into sanding it. Thanks for the info
Old Apr 8, 2006 | 06:40 PM
Chapelle's Avatar
scroll down on the OTG opening page and it says there's a 1 piece dash cover coming soon for the xB. http://www.onetongarage.com/ is that what you're looking for?
Old Apr 8, 2006 | 06:41 PM
stick_1NZ's Avatar
Designed to fit over your Scion xB's dash and instrument cluster, this 1-piece fiberglass cover is paintable and allows you to add a radical custom look to your interior without having to remove, and sand and paint your stock dash. Installation of the cover is a snap, and it is just as easy to remove to return your car back to stock. The cover will come unpainted, but will also be available pre-painted in factory Scion colors.
THIS ITEM IS "COMING SOON"
I'd suggest calling Van and inquire about it.
Old Apr 8, 2006 | 08:34 PM
soypablo's Avatar
That part is sweet! I could do some sick fab with that. But the part I was looking for goes around your stereo. the two tone piece
Old Apr 8, 2006 | 08:39 PM
Max's Avatar
Max
Just so you know, the center piece is about $200 from a dealer.
Old Apr 20, 2006 | 04:21 PM
tyrantcold's Avatar
I repainted my ***** with the method described , had no problme , might suggest just buying the carbon fiber overlay and painting that , i got mine from scionparts people i think it was 130.00 .
always make sure what every you paint that you put a clear coat over it cause paint by itself will not withstand use.
Old Apr 24, 2006 | 04:28 PM
TKE_555's Avatar
does anyone have the part number for that piece? $200? that's a bit steep.
Old Apr 24, 2006 | 04:45 PM
ack154's Avatar
I think that part is #: 55412-52230-B0
Old Jun 27, 2006 | 03:31 AM
soundwave's Avatar
Originally Posted by stick_1NZ
WOW! WHEN?!
Old Oct 20, 2006 | 05:36 AM
djeggied's Avatar
KAD
yeah what he said when
Old Oct 21, 2006 | 07:13 AM
Spike91's Avatar
Yeah i have been waiting for that piece to come out for like about a whole entire year. Its taking FOREVER!!! When is a good question!
Old Oct 21, 2006 | 06:15 PM
PRSweeney's Avatar
I had to get the dash and all of the controls on it after my headunit caught on fire. They didn't cover anything. Even worse, those parts cost almost $400 AFTER employee discount!
Old Oct 21, 2006 | 07:01 PM
Spider13's Avatar
This has been coming soon for like 2 years. I'd love to see it come out tho.
DaBlackBox
134
Apr 10, 2022 02:04 PM
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
TheTripleC
Jan 4, 2015 06:46 PM
