Short antenna !! using your OEM antenna !
Old Apr 10, 2006 | 05:13 PM
jOaNgHoSt's Avatar
Default Short antenna !! using your OEM antenna !
Here's another way you can use your current antenna to make it short and not loose the reception.
Old Apr 10, 2006 | 06:05 PM
TougeTerror's Avatar
how'd you do it?
Old Apr 10, 2006 | 06:50 PM
hieoctane's Avatar
lol yea..what exactly did u do?
Old Apr 10, 2006 | 07:07 PM
jOaNgHoSt's Avatar
All I did was to break the antenna inside the silicone portion, leaving some room inside to insert the end of the OEM antenna witch I also cut about 1 inch from the plastic and then I put some metallic glue (radioshack) inside to glue both ends and maybe fix the receptin on the antena since I basically brke the antenna in two.
Here's a simple drawing.
http://tk.files.storage.msn.com/x1pU...da2dKRh75d-V4A
Old Apr 10, 2006 | 08:48 PM
I just ripped mine apart. We'll see how it works without the glue.
Old Apr 10, 2006 | 09:00 PM
TCpete's Avatar
lol bump.. hows the reception guys??
Old Apr 10, 2006 | 10:53 PM
jOaNgHoSt's Avatar
reception is just the same as before, I used the metallic glue, but it may work different with out glue or maybe not !!
Old Apr 11, 2006 | 04:57 AM
TeoChiu909's Avatar
nice, i just did mine. before i just cut it, and painted the tip.
Old Apr 11, 2006 | 05:26 AM
chubster41's Avatar
almost looks what I did
NonStopTuning
Jun 29, 2015 07:42 PM
bluemex
Jun 16, 2015 03:22 AM
Kata
Mar 2, 2015 10:46 PM
crystaljukebox_com
12
Nov 10, 2003 09:12 PM
