head rest in evny green need some help?
Old Apr 13, 2006 | 05:00 AM
njforcedlife77's Avatar
Default head rest in evny green need some help?
i had a question when they installed the dvd head unit in my envy green xb. when you start the car one head rest well come on with out you pushing the power button.but if you turn it off before you shut the car off it will stay off when you start it up again.before i but the new dvd head unit in you had to turn both on by hand.anyone now why the one stays on and the other one doesnt?i ask the guys that installed my stuff they said they couldnt find the other power wire or something like that not really sure.maybe someone can help me def would like some comments.one other question has anyone hooked up the aux plugin to a aftermarket head unit because i wanted to any tell me how to do it?
Old Apr 13, 2006 | 05:03 AM
dbm's Avatar
dbm
Sorry, I can't help with your problem but your box rocks! the color with your rims kicks ___. Sorry for the false reply, I just had to comment. I haven't seen one in person yet!
Old Apr 13, 2006 | 05:11 AM
thanks no trouble can go here to see the rest of the pix of my xb inside and out.
https://www.scionlife.com/forums/viewtopic.php?t=114987
Old Apr 13, 2006 | 09:24 PM
usdmbB's Avatar
Most likly the problem is with the screen itself normaly Visulogic headrest come on with the ign or a switch . they will self powerup when ign. is on. Have the Installer call Visulogic and check it out.
Old Apr 13, 2006 | 10:40 PM
that what i was thinking i think they did look for a ign or a switch
Old Apr 17, 2006 | 06:15 AM
izfrog5's Avatar
I have trhw same car and both of mine only turn on and off with the power buttons only.
Old Apr 17, 2006 | 04:33 PM
i know they both turn off with the stock radio did you change you head unit to a after market one?
Old Jul 4, 2006 | 03:28 PM
teamsc10190's Avatar
Default Re: head rest in evny green need some help?
Just stumbled upon your monitor question. Sounds like your problem is that one monitor is set to 'Auto' power mode and the other is set to 'Off' power mode. The factory delivery condition should be that both monitors are set to "Off" power mode. What this means is that regardless of the monitor power state (on or off) as the car is running, the monitors will always default to 'Off' as the car is restarted. In 'Auto' power mode the monitor will default to the last car running power condition as the car is restarted. So if the monitor was on when the car was shut off, then the monitor will automatically turn on as the car is restarted. Power modes can be switched easily in a hidden menu by your dealer. The choices are 'On', 'Off' or 'Auto'.
XB06
15
Oct 1, 2022 10:24 PM
k1114
Mar 6, 2015 03:43 PM
evolving_machine
Jan 13, 2015 08:04 PM
sabegnj
Nov 14, 2003 11:54 PM
