how do i open tails?
Old Apr 14, 2006 | 03:25 AM
wTc's Avatar
wTc
Default how do i open tails?
iv been searching and found nothing, a while back i saw a post that explained how someone opened their tails, and made a custom led job. I have an extra set of tails, and i cant figure out how to open them. Can someone direct me in the right direction??
Old Apr 14, 2006 | 04:08 AM
wTc's Avatar
wTc
only thing i can think of is to maybe bake them like the headlights??? someone plz help me out.
Old Apr 14, 2006 | 04:09 AM
WeDriveScions's Avatar
Hmmm.. never played around with them... but I'm pretty sure you'd have to bake them...
Old Apr 14, 2006 | 04:21 AM
wTc's Avatar
wTc
im now searching for information on baking... not having much luck-- help?
Old Apr 14, 2006 | 04:59 AM
wTc's Avatar
wTc
well i tried the headlight method on them and it failed.. lol the taillight melted. The red/clear cover that i was trying to remove just melted and sank in.. i did it at 250 -- for about 15 min.. and even with it all melted it still wouldnt open... so thats out.
Old Apr 14, 2006 | 05:04 AM
How'd you do it? it's not just throw it in and such...
Never in a gas oven, never on broil, the oven must be preheated, it shouldn't be above 250, it should be on a cookie sheet, with something cushining it from the direct heat of the sheet, like a folded cloth or something... and you should watch it every second, unless you've run it before.
I've heated up two sets of headlights multiple times with not an issue in the world... would be totally surprised if the tails were much different.
Old Apr 14, 2006 | 05:50 AM
kileil's Avatar
I'm fairly sure they're molded together and can only be opened by cutting the front from the back. I guess wait a day to see if anyone has any other ideas, if not take a dremel with a cutting disc to them and cut far enough back that the incision wont be visible once reinstalled.
Old Apr 14, 2006 | 11:43 AM
Billman's Avatar
https://www.scionlife.com/forums/vie...=g35+led+tails
Here's the post your were looking for...you def have to dremel them open, the baking technique doesn't work...but I guess you found out the hard way. Go to a junkyard or look online and I'm sure you can find another set for under $100. G/L man! [/url]
Old Apr 14, 2006 | 05:21 PM
davedavetC's Avatar
just fixed the link for ya.
Old Apr 15, 2006 | 03:36 AM
wTc's Avatar
wTc
im not the brightest crayon in the box... can anyone whip up a pic of where to cut it?
Old Jun 1, 2006 | 07:00 PM
English's Avatar
bump, bought a new set of tails on ebay..$36 shipped!!!!
Planning on doing the led retro
Old Jun 1, 2006 | 07:20 PM
THansenite's Avatar
I wouldn't think baking the tails would be a good idea. The headlights are meant to be able to withstand higher temperatures because the lamps get pretty hot when they are run for hours at a time. Brake lights are intermittant with full power going to the bulbs only when you hit the brakes. They may be warm when you have your lights turned on, but I highly doubt they get anywhere close to the temperature the headlights get.
Old Jun 3, 2006 | 01:59 AM
magyver's Avatar
im doing a retro my self soon.. but i dont plan as of now to even come close to opening them up.. drill a hole for the led to peek through, stick it in there, then caulk around it.. done..
Old Jun 21, 2006 | 03:56 AM
English's Avatar
If you plan on extending the wires from the truck module, where are you going to put the circuit board?
rmz489
Scion xA Aero & Exterior
Sep 17, 2015 03:24 PM
Threequalseven
Aug 26, 2015 04:24 PM
umnitza
Jul 25, 2015 07:54 PM
