TRD Exhaust Walkthrough/Instructions
Old Apr 17, 2006 | 03:05 AM
7thgear's Avatar
Default TRD Exhaust Walkthrough/Instructions
I searched but I couldn't find any... I guess it's pretty basic then right?
Old Apr 17, 2006 | 03:16 AM
sebhockey's Avatar
Install is about as straight forward and easy as it gets. Remove two bolts and remove old muffler from rubber hangers, put new one on rubber hangers and replace bolts, about a 10 minute install.
Old Apr 17, 2006 | 03:37 AM
7thgear's Avatar
ah, thank you. i just wanted to make sure since here on scionlife.com, there seems to be a walkthrough on just about everything possible.
Old Apr 17, 2006 | 03:41 AM
The_Instigator's Avatar
Save yourself some time by giving the threads on the bolts a good shot of WD40 or some other penetrating fluid. Also spray the exhaust hangers right before you take them off...it will make removal much easier
Old Apr 17, 2006 | 03:45 AM
ricexizxgood's Avatar
Yep. WD40 is the best
Old Apr 17, 2006 | 05:03 PM
7thgear's Avatar
thanks for the tip!
Old Apr 17, 2006 | 07:33 PM
tCb00b's Avatar
I am going to do a write up as soon as I get the time to. I installed mine maybe two weeks ago and it took me(one man) 40mins to do it. I'll write the how-to after work.
Old Apr 17, 2006 | 08:11 PM
Petem's Avatar
wow.. 40 min.. ? it should only really take like 5min.. 10 at most... the hangers are the only pain.. be carefull with using any type of lubricant on the hangers.... while it does make it easier to remove the muffler , it may cause the rubber to disolve... i used silicone grease on the rubber to make it easier to remove and install... and found that between the heat and the lubricant.,. it sort of made the rubber slightly desolve...
Old Apr 17, 2006 | 09:33 PM
7thgear's Avatar
i'll be looking forward to it. thanks.
Old Apr 18, 2006 | 03:17 PM
tCb00b's Avatar
Alrighty 7thgear, here is the link if you didn't see the thread on the page.
https://www.scionlife.com/forums/vie...503764#1503764
hope it helps
Old Apr 18, 2006 | 05:43 PM
terra_tC's Avatar
yup, quick and painless. if you need some extra umph with the hangers, lube them up and bust out some large channel locks to squeeze (one end on the hanger and one on the rubber) and it slides right off
Old Apr 18, 2006 | 09:05 PM
7thgear's Avatar
thanks a lot tcb00b. really appreciate it.
DJ_FroZone
25
May 30, 2019 07:17 PM
Krysune
Apr 30, 2015 02:25 PM
stayintrucha
Mar 17, 2015 08:45 PM
mark13018
Feb 6, 2015 08:57 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
