is pully swap bad for car?
It sounds great - an extra 9ish hp just by changing your water and alternator pully ... but how good is this for your car? Please only leave feedback if you are 100% sure of your answer. Thanks for your help guys.
i think its ZPI makes just a crank pulley that is usually the one that you replace(as far as i know) i can't really say for sure if changing if changing the alternator and the water pump would really do much. I know most kits sell the crank pulley and some of the better ones for other cars i have seen replace them all but then your talkin so major cash for a small amount of power. one thing you could do is find out if you can remove the airconditioner and the power steering but the your giving up driveability, but that show make a bigger number on the dyno
from what i heard from the guys at NST, its about the crank pulley, the accessory pullies help out, but you cannot really do those with out the other, as for the battery charging i hear with the Tc that is a very very rare problem, you would have to be running a smassive stereo to get the alternator to not work right, and not charge the battery with the pullies, im installing mine this weekend... WEEEEEEEEE!
260 for a new set of pullies, install yourself nets you around 10 wheel horsepower. that's 26 dollars per horsepower.
the supercharger, plus installation/reflash i'd say on a good day goes for say 3500 bucks. that mod will net you 60 wheel horsepower or so. that comes out to ~58 dollars per horsepower.
I guess pullies don't look all that bad now eh?
if it does start giving you problems, try running 1/0 gauge wire from the chassis ground point to the negative terminal, positive terminal to the alternator, and then the engine block to the chassis. doing this will help completely ground everything out and help eliminate dimming that you might see. if that doesnt work, you might want to think about a high output alternator and/or new/2nd battery.
killer job on the math and all that is has been done except fot the yellow top. i have been impressed with the charging system so far no light dim no hard starting and there is no capaciter or anything but i also have no pulley swap i have only had the car about a month.
The question has been hammered out many times before... please search for Crank Pulley Harmonics and you'll get everything you need and a ton of things you don''t.
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
TheTripleC
Jan 4, 2015 06:46 PM
