View Full Version : How do I take off the driver's side door panel?
McG_XB
09-07-2003, 06:02 AM
I've been noticing a small bit of rattling from the driver's side door panel when I'm playing music that has a lot of bass. I want to take the door panel off to investigate, but I don't want to mess anything up. Could someone give me a detailed description on what screws and such need to be taken out so that I can check to see that my speaker is tightly secured or so that I can dampen whatever it is that's causing the annoying rattle? Thanks
allblackxb
09-07-2003, 06:09 AM
Sorry, i can't help you on this one but i have the same problem also.
GreatWhitexA
09-07-2003, 06:27 AM
ahhhhhh!!!...i have that same problem tooo...errrr.
JDMxB
09-07-2003, 06:28 AM
Yea, i have the same problem...it's annoying as hell too.
Djuan
09-07-2003, 09:53 AM
I saw my stereo guy do it really quick, I just saw him grab it and rip it off, Ill hit him up tommorrow to find out if there was anything special.
aznr1c3bo1
09-08-2003, 05:09 AM
ooo meeee 4!! its really starting to annoy mee. i checked the passenger side and there is no problem.
McG_XB
09-15-2003, 08:26 PM
I think I may have solved the door panel rattling problem...
Today while I was at lunch I was listening to something with some bass that was causing the annoying driver door rattle... It's been annoying me for some time now and I still haven't had the nerve to take the panel off and investigate. Anyways, it was rattling and irritating the hell out of me (as usual) so to cool off, I roll the window down and it stopped rattling. If I roll the window all the way up, and stop pressing the window roll up button just after the window seats itself in the window seals, it's all good... no rattling :), but If I let it keep going past the seal, rattling comes back.
I hope that sounds clear and I hope that works for everyone else that's having the same problem.
09-15-2003, 08:32 PM
Well add my name to this long list, ya got base...ya got'a rattle!
Rhobz
09-15-2003, 08:54 PM
All along the bottom and sides of your door panel are pop clips. You just stick your fingers in between the panel and the door and pull, straight.I usually start at the bottom corner closest to the front and work my way in both directions from there. Then, the top of the panel hangs in the window slit so once all of the clips are out, you just lift the entire panel upwards and off the hanger. Be sure to unplug the window and lock controls before you try walking away with your panel. :lol:
McG_XB
09-15-2003, 10:14 PM
Rhobz, thanks for the reply on how to properly take the door panel off.
Rhobz
09-15-2003, 10:28 PM
Hey guys...I forgot to mention that there are 2 screws. One is in the door handle (armrest) and the other is in the door release lever piece. Take those out first. Sorry about that. I forgot. :oops:
swtbabiboi4u
09-18-2003, 12:41 PM
my whole car is a massager =) considering i have a 15" in da back of mah trunk dumping away :D :shock: :D :shock: :D :shock:
eric_m
09-18-2003, 04:11 PM
only one 15? why not 4?
randode
09-18-2003, 04:34 PM
4 15's didnt see no wires, and then i heard boom from the amplifiers
showpaojoe
09-18-2003, 05:55 PM
Now with the rattling noise, I just got one last night but I don't thinnk it's the door. It's on the driver's side and happens everytime I step on the break slightly harder than normal. I don't even need to be going fast but when I hit the break, there is a weird rumbling noise. Any suggestions?
DoNuT
09-20-2003, 09:35 PM
From what I've noticd, the arm rest is the problem. I started feeling around when the bass would hit, nothing would help, then the arm rest stopped it. I figured it might be one of the window buttons, I held each one individually, still rattling. If I held them all at once, the rattling would stop, or if I put pressure on the whole bezel. So for those of you taking your door panels off, look into the arm rest.
Male_Nurse
09-23-2003, 07:08 AM
I would suggest since your panel rattles, to get DYNAMAT. That should take care of your problem.
Djuan
09-24-2003, 09:08 AM
I need a Dynamat for the rear quarter panel on the passenger side, my speakers bend the metal... http://www.scionlife.com/forums/images/smiles/icon_cry.gif
eric_m
09-24-2003, 04:06 PM
can't pay my rent
'cos all my money's spent
but that's okay
'cos I'm still fly
JDMxB
09-24-2003, 05:40 PM
got a quarta tank of gas...
In mah new EcLass...
randode
09-24-2003, 06:22 PM
But that's alright cause i'm gon' ride
got everything in my moma's name
but im hood rich da dada dada da
swtbabiboi4u
10-14-2003, 06:32 PM
ahh hahah damn look what i did =( i got the whole forum ta sing, woot woot :D ryte on guyz!
o4_USDM_bB
02-10-2004, 10:53 AM
sorry to dig up old posts, but i was taking off my door panel today to dynamat it. i couldn't figure out how to remove the harness for the window controls. normally it's a simple push thingie that you squeeze and then pull. this one wouldn't budge. can anyone help me out? i don't want to break the harness, especially the drivers door one.
