TheIcon
04-19-2006, 12:23 PM
Ok so I did some work on my car in the past month. Now the ABS, Check Engine, etc lights are lighting up on my dash. How do I get rid of them.
Is this the answer?
http://www.scionlife.com/forums/viewtopic.php?t=33062
dgHotLava
04-19-2006, 12:29 PM
that would be fine for the CEL, but the ABS thing is not gonna get fixed that way.
what work did you do?
did you forget to plug something back in???
did you damage a wheel sensor???
TheIcon
04-19-2006, 04:08 PM
Ill have to check again abou tthe ABS. I tried to take a quick mental note of which lights I saw. I thought ABS was one of them.
I took my dash off and speedo off. Also took my battery out. Installed lowering springs. That was mainly the bulk of it.
dgHotLava
04-24-2006, 01:08 PM
if you did lowering springs you might have damaged one of the wheel sensors...
it does not take much to ruin them...
TheIcon
04-24-2006, 06:53 PM
Yea I checked the other day and the ABS light wasn't on. Reseting the ECU took care of it. :)
stick_1NZ
04-24-2006, 11:17 PM
One thing I've encountered recently on an xB was a kid installed his cathodes and the lights to the ABS wire causing the warning lights to come on.
TheIcon
04-25-2006, 04:15 PM
Thats interesting. I don't see how that is even possible.
