Question for people with OTG camber shims
Old Apr 19, 2006 | 04:10 PM
stankubrick's Avatar
Default Question for people with OTG camber shims
If you've had an alignement done, how much was your toe off? and what is your drop and wheel width and offset?
TIA
Old Apr 19, 2006 | 05:44 PM
eXciteBox's Avatar
Signature Visions
i havent had an alignment done, but toe is DEFINETLY noticeable.
im on tanabe df210's going to tein basics soon, and as you know im on Lover Souls and they are 17x7 +25 . i also have the OTG hub spacers so i guess that makes my effective rear offset +15. im sorry i dont have more info. i hope this helps
Old Apr 19, 2006 | 06:45 PM
blitz_xb's Avatar
i have the shims and df210s and i have no visual problems w/ mine
Old Apr 19, 2006 | 07:04 PM
I am still planning to lower the car some more, and space out my wheels more too....I was just wondering how bad my toe can get.
My rears wheels toe out just a bit past specified range...
L: +0.34 R: +0.61
Specified range: 0.00 to +0.33
BTW, I'm runing Garson camber shims right now....definitely not as nice as OTG. Both have toe correction, but OTG looks much higher quality.
Old Apr 19, 2006 | 07:07 PM
suspended's Avatar
my alignment toe was only .01 with the camber shims....from what i've heard, they are made to be optimal at like a 2.5" drop....not sure if thats true though, but no complaints from me after going on the alignment rack
Old Apr 19, 2006 | 07:11 PM
eXciteBox's Avatar
Signature Visions
L: +0.34 R: +0.61
how can you space your wheels out more?
Old May 24, 2006 | 11:07 PM
Ed's Avatar
Ed
Bringing this thead back to life,I haven't been around lately Can you guys post your rear camber measurements too?
Lowered with Goldlines,rear camber shims are OTG. Installed them myself @ work and put the car on the alignment rack right after. I didn't check alignment before the shim installation.
Camber was almost the same on both sides: -4.1 degs driver side,-4.3 passenger side (looks very agressive). As a comparison,the fronts are 0.8 driver side,-1.2 passenger side.
Rear toe is pretty positive (toed out)
Driver: -.14
Passenger = -.06
I didn't do any adjustments afterwards. I'm installing Specialty Products 75800 rear shims to adjust rear toe back to zero,then readjust the front angles (camber,toe).
Old May 25, 2006 | 12:30 PM
BrianxB's Avatar
My toe is effed on my car with the OTG camber shims.
Its sitting at -4 degrees and the numbers are somewhere around
L- .42 R-. 69
Something like that. Ill have to look the paper.
bootlgr
Jan 26, 2016 01:22 AM
scionhawaii
13
Jun 19, 2015 03:59 PM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
