need help!!!
Old Apr 21, 2006 | 05:10 AM
chaitea's Avatar
Default need help!!!
i installed the halo projecters but the only thing thats not working is the halos. i dont know which wire to connect so if you please post really good pictures like where all the wires are connected that would be very helpful. also how do i change my tailights. i bought a set from ebay. they are altezza with three ovals in black. pictures would be great. thanks
Old Apr 21, 2006 | 05:24 AM
Max's Avatar
Max
Well you will need to tap into the turn signal wiring for the halos. I used a multimeter to determine which was the constant power (not flashing with the turns) but I do not remember what's what. There are three wires going to the turn signals. IIRC, I used the outer two, not the inner one to tap into, but I do not remember the polarity.
For your tails... take off the plastic pieces in the rear. It's pretty obvious, they are the only ones which pop out in the back corner. Take a 10mm socket and unbolt each of two nuts holding the tails in. DO NOT DROP THE NUTS. There is a single wire harness attached to the center bulb. 1/4 turn pops it right out. After the two nuts and the center bulb, they will come right out. Very simple. Install is the opposite. I used to have similar taillights.
Old Apr 21, 2006 | 09:49 AM
bB2NER's Avatar
Music City Scions
Yeah, turn on running lights and test to see which wire is hot.
Tails are a piece of cake the 2nd or 3rd time. lol
Hint: after loosening the 10 mm nuts, remove them by hand. It makes it easier to NOT drop them.
Old Apr 21, 2006 | 06:51 PM
chaitea's Avatar
Default so
after finding out which wire is which, where do i hook up the black and red?
Old Apr 21, 2006 | 08:04 PM
bB2NER's Avatar
Music City Scions
Ground the black and splice tap the red one into the hot running light wire. This will turn on the halos when the running lights are turned on. Hope this helps!
