Need Help with questions about bazooka tube!
Old Apr 25, 2006 | 12:58 AM
Bonger6693's Avatar
Default Need Help with questions about bazooka tube!
Hello, this is my first post and I am in need of some help. I just picked up my new 2k6 xB today and its amazing . The question I have is I have my bazooka tube from my old car and was wondering if anyone has hooked up a 10" bazooka b4 in a xB? I searched everywhere and all I see is 8", I went out and it sticks out which I knew it would. Now does anyone know the best way to set it up? I guess I might have to turn it instead of letting it stick straight out. If anyone has anything to throw in like if it will even work, please fill me in before I go on with this. Thanks!
PS: It is a RS model 150watt.
Old Apr 25, 2006 | 01:18 AM
UT-S_HAXX's Avatar
take out the sub its self and cut the tube to where you need it
Old Apr 25, 2006 | 01:29 AM
Max's Avatar
Max
What?
Correct me if you are wrong, but bonger is talking about a swap on the whole tube, and not just the speaker, correct?
Old Apr 25, 2006 | 02:31 AM
Bonger6693's Avatar
Yeah I just want to put the 10" Tube in..just wondering if anyone has used it b4 since it only fits the 8" straight back not the 10". Thanks.
Old Apr 25, 2006 | 07:43 AM
bdk323's Avatar
hey bonger I just installed a 10 I had in a acura your going to have to turn it I bought universal mount rings for it and it looks pretty good and I wouldnt recommend cutting the tube Im not an audio pro but I know that it was meant to have the dimentions it has to give the best possible sound for what it is
Old Apr 25, 2006 | 02:53 PM
ProshopXB's Avatar
Just turn the tube like you said, firing at either the driver or passenger side rear panels. It won't be quite a much bass as firing to the rear, but it will get the job done for you. Easy as that no big issues what so ever. Hope this helps.
Old Apr 25, 2006 | 09:28 PM
Bonger6693's Avatar
K sounds good, just wanted to make sure i wouldnt hit anything under the car when i place it down with ties or whatever I use . Any ideas about wiring it up? My friend that knows a lot bout it says that he could tap into the rear speaker or something..will that work? Or will I need a part or harness?
Old Apr 25, 2006 | 09:44 PM
ProshopXB's Avatar
Well if you still have the plug that comes with the bazzoka tube, you should be alright using the rears for a high level in for a signal and you will also need a 10 awg power kit to run it. Just make sure if you screw the tube down with straps or brackets, that you make sure you dont hit the spare tire.
Old Apr 26, 2006 | 07:15 AM
bdk323's Avatar
Just like pro said its pretty straight foward with the plugs that come with the tube and either start the screw's,pull the cover off and cut them so they dont hit the spare or get shorter screws good luck!
bootlgr
Jan 26, 2016 01:22 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
toyotaisme
Jan 10, 2015 10:24 PM
Besk_one
Jan 17, 2004 01:52 AM
