20" tire size
Stock Tire - 215/45R17 >Search Tires Tire 1 - 225/35R20 >Search Tires Tire 2 - 225/30R20 >Search Tires
Section Width: 8.46 in 215 mm
Section Width: 8.85 in 225 mm
Rim Diameter: 17 in 431.8 mm
Rim Diameter: 20 in 508 mm
Rim Width Range: 7 - 8 in
Rim Width Range: 7.5 - 9 in
Rim Width Range: 8 - 9 in
Overall Diameter: 24.61 in 625.09 mm
Overall Diameter: 26.20 in 665.48 mm
Overall Diameter: 25.31 in 642.87 mm
Sidewall Height: 3.80 in 96.52 mm
Sidewall Height: 3.10 in 78.74 mm
Sidewall Height: 2.65 in 67.31 mm
Radius: 12.30 in 312.42 mm
Radius: 13.10 in 332.74 mm
Radius: 12.65 in 321.31 mm
Circumference: 77.31 in 1963.6 mm
Circumference: 82.30 in 2090.4 mm
Circumference: 79.51 in 2019.5 mm
Revs per Mile: 845.1
Revs per Mile: 793.8
Revs per Mile: 821.8
Actual Speed: 60 mph 100 km/h
Speedometer1: 56.3 mph 93.9 km/h
Speedometer1: 58.3 mph 97.2 km/h
Speedometer Difference: - Speedometer Difference: 6.462% too slow Speedometer Difference: 2.835% too slow
Diameter Difference: - Diameter Difference: 6.07% Diameter Difference: 2.77%
here's a readout of the different tire sizes. the top is the stock 215/45/17, middle is 225/35/20, and the last is 225/30/20.
for the rim itself, it will extend 6mm in and out. this means you'll have 6mm less clearance towards the strut and 6mm more towards the outside. this shouldnt cause many problems if at all.
i'd go for the 30 series, but do NOT run over anything rough. that's a very thin tire and will pop whe shocked by a pothole or something.
ya it takes a lot to pop the tire, im running the same on my xb and ran over a 4 x4 which trashed the rim but never popped the tire and they still hold air with no leaks cause im running on busted ones right now till the new ones come in
Originally Posted by Vas_Finest
Naw man. I need tires in the worst way.
This is what I'm rockin until the middle of summer.
I think I am going to sell the 20s and drop down to some 18s (too many issues w/the 20s).
Ive hit a bunch of hard potholes in my 19's have had no trouble...
Originally Posted by NCBIGGJ
I have 20's on mine and use the 225-30-20. I daily drive this car. I just pay attention on where I am going all the time. You should'nt have any issues at all.
because I was 18 before and i use to drive like a moron
Another thing. No matter how safe you drive, you can not dodge every pothole----- especially on the interstate. If you are going 70 (the speed limit) and you hit the wrong pothole or bump, its a wrap.
I don't want to start a riot, but please believe I am speaking from very deep experience with the tC and 20s. I've had mine dropped on different sets of 20s and a couple of different springs. 20s are alright for everyday driving (except in Hampton, VA "pothole city"), but I wouldn't recommend them for traveling.
Normally I don't really care about petty issues like this, but I don't want someone to go through the same issues I went through.
munch said it............
tires are really well built, the will not just "pop" on a whim, you need to really hit something hard and fast like a pot hole that is 3 inches deep, i have run up to 24"s on my denali running what would be equivelent to a 30 series for a car (305/35-24 front and 315/25-24 rears) and never had an issue........
i think unless you run a 19,20 or above you really dont have first hand knowlege of the subject other then what a freind told you or what you read.
it takes skill to drive a car with large diameter rims and some people have it and some people don't you do have to pay attention and you cant drive like a idiot over railroad tracks etc.
i say run them and be happy
I just ordered 20's for my '06 Xb. I hope they fit. Theyre getting wrapped in some 225/30/20 tires, I just have stock suspension right now, so I dont think I'll have any problems.
