OFFSET QUESTION-HELP
Old Apr 26, 2006 | 01:49 AM
fescom's Avatar
Default OFFSET QUESTION-HELP
OK, I understand what offset is, but, what offset would you use to not have to use spacers at all?
Offset moves the wheel in or out but what is positive offset and what is negative offset, I mean does +40 offset versus +45 oddset mean that 45 offset makes the wheel stick out more than a +40 offset or ie: move the wheel out more?
I would like to use 18 inch wheels from ADR, what offset do i need to get to not have to use spacers and how big a tire can i stick on them without rubbing or other clearance issues?
wheels
http://i12.ebayimg.com/05/i/06/ea/2c/bd_1_b.JPG
2006.5 polar white XB
Old Apr 26, 2006 | 03:58 PM
Subcompact Culture's Avatar
Basic thoughts:
•Do not run higher than a +45 offset on an xB w/o spacers.
•Anything between +40 and +20 you should be fine w/o spacers.
•The higher the offset, the closer to the body the wheels will be.
•A negative offset pushes the wheels WAY out. You probably won't want to run that. Think rubbing (or at least a lot of bodywork not to rub if you're lowered). Most cars with real low offests (think +20 and under) are rear-wheel drive.
Hope this helps.
Old Apr 27, 2006 | 01:48 AM
fescom's Avatar
Thanks a bunch I now understand mch better.
mark
Old Apr 28, 2006 | 01:58 AM
BrianxB's Avatar
if you order a set of wheels with the same offset front and rear, spacers will make the rear look even with the front as far as spacing goes since the xB and xA have that weird look in the back where the wheels sit too far in. This is why many run OTG shims.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
