View Full Version : Tien SS
xboxPS2
06-04-2004, 06:40 PM
are these the ones that are remote controlled so u can adjust from the drivers seat?
i'd rather have these than spending like 3 grand for bags installed.....
Holler at me
Jeff
JDMxB
06-04-2004, 06:50 PM
Some Tein SS systems feature a Tein upper mount that is compatible with the EDFC--which is the Electronic Dampening Force Controller.
This doesn't not raise/lower the car from inside--this only adjusts the dampening.
Also, the Tein SS system for the xB does not feature Tein upper mounts, you must reuse your stock ones.
So no EDFC for the xB when using the Tein SS.
DJ_SpaRky
06-04-2004, 06:54 PM
Check this out:
octopus3699 (http://www.scionlife.com/cgi-bin/reg/reg.cgi?db=default&uid=default&view_records=1&ID=*&Model=&Color=&County=&State=FL&sb=5&nh=58&mh=1)
xboxPS2
06-04-2004, 06:58 PM
good thing that link didn't work but i did a search and it had NO MATCHES at all sry
Jeff
JDMxB
06-04-2004, 07:00 PM
That Tein xB in FL had CUSTOM made upper mounts in order to use the EDFC.
If you want to talk about all the things you could do with unlimited money and not out of the box functionality, we could shoehorn a Big block V8 into an xB.
Without doing major custom work (as in getting custom upper mounts made by Tein) you will not be able to use the EDFC on any of the Tein Coilovers currently out for the Scions.
xboxPS2
06-04-2004, 07:05 PM
i've never seen the xb with the edfc, i've seen them on celicas and such and was just wondering thanks for the info....any ideahow much those custom upper mounts cost that guy have a pic?
Jeff
