question about a custom in-floor sub system
Old Apr 26, 2006 | 04:46 PM
05FMtC's Avatar
Default question about a custom in-floor sub system
now that i got all of my questions answered about ohms, speakers and what not im ready to get the ball rolling on this. i want to make a in-floor system kinda like qwd's box but i want to keep the spare. i dont mind raising the floor a bit but i want to keep the spare. i am going to get one more jl audio 10w1v2 and a 300/2 amp. the subs need .625 cubic feet per sub. u guys think that there is enough space to make somthing like what i quickly drew up below w/o having to use any fiberglass? i want to keep it all mdf. thanks.
Old Apr 26, 2006 | 05:19 PM
G-NIZZLE's Avatar
yes and no ... yes you can make it out of all mdf ,, but the box will need to be higher the make up for the lost space around the tire .... if you fiberglassed it .. you would regain that space and the box could be lower.... this sounds like a great project .. wish i had a tc to try it out on ...
Old Apr 26, 2006 | 06:11 PM
ZoD's Avatar
ZoD
wow, um... you're going to have several problems. First, the spare will be almost unusable if you do it that way out of MDF because the box would be incorporated into the floor making it difficult to remove it (you can split the box into 3 pieces with extension "wings" which would help). Second, if made entirely out of MDF it would be quite heavy and awkward to remove. Third, those subs have a mounting depth of 4.5 inches. If you add the width of the MDF which .75 and venting off the motor you are looking at somewhere around 6.5 inches of depth. That may no seem like alot but with the spare in and doing it MDF the highest point of the spare is going to be where you raise the floor from making you floor high as all hell.
Not saying you shouldn't do it though. Just saying you will have to raise your floor higher than you think.
Old Apr 26, 2006 | 10:13 PM
-Keith-'s Avatar
No there not enough deepth in the spare unless your gonna raise your floor up and build a false floor...
Just do like me and my crew do... Through the spare in a trash bag and toss it either on top of the enclosure or in the back seat.
Old Apr 26, 2006 | 11:58 PM
L4rry_B1rd's Avatar
WOW, I should try that.
Old Apr 27, 2006 | 12:30 AM
-Keith-'s Avatar
Well I build custom boxes all the time. And you want somthing nice or nice and hidden then you have to give away some stuff...
Ussually I do a false floor at the same level then just sink the sub in so you can through a spare on top and it wont damage nothing.
Old Apr 27, 2006 | 12:36 AM
L4rry_B1rd's Avatar
Im not ragging on you at all. I know your ____ is hot. Just found that really funny
Old Apr 27, 2006 | 01:46 AM
mandos's Avatar
hmm...garbage bag...nice idea...I usually just rest it in the back seat.
Old Apr 27, 2006 | 01:50 AM
-Keith-'s Avatar
its dirty... i dont care if ur cars brand new... that thing is dirty still lol
Old Apr 27, 2006 | 05:26 AM
05FMtC's Avatar
i just took the floor out and looked at it. damn i feel like a dumb ___ for asking this now. the only reason that i want to keep the spare is because i tend to go one random long excursions from time to time and i dont want to get stuck somewhere w/o a spare. it happned to me in my old car and it sucked really bad.
Old Apr 27, 2006 | 06:19 AM
honey0bucket's Avatar
AAA is your new best friend...
Old Apr 27, 2006 | 07:44 PM
05FMtC's Avatar
that could be a possibility. however, what do u guys think about just 1 10w1 in the floor w/ the spare still there? i think that can work. right now i have it in a truck box which is .70 cu. ft but i think its not the right type or somthing b/c sometimes it distorts i think. it still hits hard on all 120 watts that my e1200 is pumping into it.
Old Apr 27, 2006 | 08:20 PM
-Keith-'s Avatar
If you want to leave the spare in your still gonna have to build a false floor...
Old Apr 28, 2006 | 02:13 AM
cdubber9's Avatar
Here's my floor sub box. It's not all the way complete, I'm thinking of mounting the amp to a removable pice of wood in the spare tire. Then I still need to come up with a way to level out the floor using the stock hatch cover. Suggestions are more than welcome.
Old Apr 28, 2006 | 02:33 AM
-Keith-'s Avatar
take the old cover make a template for the new false floor out of whatever your gonna make it out of... I suggest at least 1/4 mdf that way it has some kind of strenght. Then build bracing under it to level it out.
Old Apr 28, 2006 | 05:57 AM
05FMtC's Avatar
dude i love that. whats the airspace like on that? it would be great if you can get if you can some dimensions of the box. thanks.
Old Apr 28, 2006 | 01:58 PM
cdubber9's Avatar
I measured it to be about .70 cubic feet. The sub I'm using is a 400 watt Memphis 10" and I believe it called for .75 sealed, but that's about as much as I could get out it without makeing it any deeper. The depth is 5" and and another 1/12" of wood, which puts it about 3" above the original floor.
Old Apr 28, 2006 | 02:07 PM
Nick06tC's Avatar
Cdubber, Thats the same setup I did.
Old Apr 28, 2006 | 02:38 PM
cdubber9's Avatar
Nice, what did you use for the floor board and where did you get the carpet to match. Im still debating if I want to make the floor flush with the box, or the way you did it. I have an 350W Alpine amp thats kinda small so I'm thinking of putting it in the spare tire.
Old Apr 28, 2006 | 02:42 PM
Nick06tC's Avatar
I had mine done at a local shop. The floor is 1/2 inch I think, plywood carpeted. They just traced the factory floor and cut it to fit. That way its sturdy and if I want I can take out the system and put the stock floor back in. Its all tight and doesnt move. Thats a JL12 with a very deep mounting so it can be made to fit most subs.
