Suggestions for Sirius Starmate install in xB
I recently purchased a Sirius Starmate (I need to move it between cars and the house so I didn't go with a hardwired tuner) and am looking for suggestions for installation.
What I am thionking about is mounting it where the OEM rearview mirror was since I replaced that with the Gentex mirror. I am borrowing a picture from tanakasan's Gentex install thread to show what I am working with.
I need two things:
1. Is there a mount out there that I can drill holes in the base of to mount it up here?
2. What's the easiest way to hardwire it since I don't think the plug that comes with it is long enough to go across the front, down the pillar and then to the lighter?
I need two things:
I was the one who PM'd you on how you did it
If I had the OEM mirror I would go that route but I have a black square up there with 2 holes for screws that would be perfect for mounting the Starmate
if I could just find the right mount - one that will cover the spot and I can drill a couple holes through for the screws.
hmmmmm only way i can think of is making maybe like a small wooden mount wrapped in cloth or something
kind of cool but isn't that a pain in the ___ to change the channels? I know just adjusting the mirror it seems like it is a mile away from me. Unless it has a remote in which case that would be alot easier
It does have a remote.......
I found http://www.ram-mount.com . They have just about everything imaginable to mount anything you can think of (carputers, GPS's, XM, etc.) but nothing specific for Sirius. However, they do have mounts with a standard AMPS plate I can use so I may try this (but a bit pricey!). Will need to have the Starmate in-hand to see about easy removal to move to the other car or the house. Here's a pic:
That could work, too. Have t ofill that hole up there with something else. How did you mount it to the dash?
Cool - thanks for the idea. I guess I'll put my "Air Spencer" where the mirror used to be
Also found this thread to do the hardwire:
https://www.scionlife.com/forums/viewtopic.php?t=109276
lunchbx05
Dec 11, 2014 06:13 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
Mark
