Aftermarket Brake Pad Squeeking
I was looking to buy some new brake pads for my tC.. I don't need new rotors yet, just pads.
I had alot of problems with odd sounds with my last car unless I put ceramic pads on it.. (it was an '02 eclipse).. It would make all types of horrible sounds when the pads were cold. Once I put the ceramic pads on, I had no problems.
I was wondering if anyone has any problems with any aftermarket pads?
Right now my stock pads don't make any noise at all, so I don't want that to change.
Does anyone have any good pads they would recommend? If so, where did you order them?
Unless you are heavy footed, stop frequently, or drive with two feet, I would recommend having them checked out before replacing the pads. Putting brakes on at 20K sounds really early. Only reason I changed mine out was to replace the stock with ceramics. . . I wanted to try out a set.
sIcKsCiOnS
DelMarVa
Scion Tuners
20k is not early for brakes
avg. mileage car i do brakes on here at the dealer is 15-20k
with this stop/go traffic it takes a tole, yes you can go WAY longer on first set of pads, but it all depends on how you drive, conditions you drive in,amount of weight you carry, etc.
with aftermarket pads you gotta be careful what you choose, alot of them are noisy and can't do anything about that.
i upgraded my rotors and slapped hawk pads on, which i think work awesome, no noise at all. i have also heard good things of Axxis Ultimates as well
i rec. to stay away from EBC pads, not a good choice
Hey scionbandit we should get together sometime and swap some storiesand grab a beer. . . I think it would be fun. So you like the hawk pads? I was think about gettin some and some powerslot rotors next brake job maybe a set of SS brake lines.
are you going to upgrade the brake hoses too? I'm pretty much sold I have a distributor who's been trying to sell them to my shop but I am going to have to see on my car first. . .ha ha ha
A slotted rotor has grooves machined into the rotor face to increase the bite of the brakes and to celan the brake pad surface to reduce high temperature glazing of the pads...
Pic:
The are literally thousands of brake pad compunds out there for a variety of applications but there are some limitations for the tC front calipers. For a low dust, low noise pad that improves performance over stock, the Hawk HPS probably the best choice. For something with much more bite although dusty the Axxis Ultimate is a great choice and is essentially the highest performance street pad available. There are a few more options but if you are looking for increased performance over OEM pads, these 2 compounds should be on your short list.
Pic:
I don't really care about the brake dust, I just want something nice and quiet.
Any street pad will be quiet as long as it is well bed-in. For the most part they are all quiet although the Axxis Ultimate has been known to have some reports of noise. More often than not they are reported to be very quiet.
bed-in istructions available here:
https://www.stoptech.com/tech_info/w...contents.shtml
I disagree, EBC "green" are on my other current car, and I like 'em a lot, also had them on a previous vehicle, no issues. I'll likely try a set on my tC when the time comes, and feel they'll make a big improvement over stock, shouldn't require as much pedal effort since EBC will grip much better.
..the Hawk HPS probably the best choice.
About double the price of OEM brake pads.
sIcKsCiOnS
DelMarVa
Scion Tuners
sIcKsCiOnS
DelMarVa
Scion Tuners
i didn't pay $80, but it was worth the money i spent
i have a few extra sets for when i hit the road courses
its a completely different quality pad
