How do i make my XA ride quiet like a Lexus?
Old Apr 29, 2006 | 04:12 PM
Master's Avatar
Default How do i make my XA ride quiet like a Lexus?
Hello,
I just did a search for sound deadening but they did not specifially answer this question.
What kind of sound deadner or mat should i use to make my XA feel super quiet?
and which area's are most prone to road noise? thank you.
Old Apr 29, 2006 | 04:58 PM
UT-S_HAXX's Avatar
dynomat works good
Old Apr 29, 2006 | 04:59 PM
UT-S_HAXX's Avatar
heres a how to its for an xB but same concept and the xA and xB arent that different https://www.scionlife.com/forums/viewtopic.php?t=65529
Old Apr 29, 2006 | 05:09 PM
smokeydog001's Avatar
https://www.scionlife.com/forums/vie...ighlight=edead
Old Apr 29, 2006 | 05:24 PM
mavrichie's Avatar
I have dynamat installed all over the interior of my box and it is super quiet on the freeway and around town but it does not ride like a Lexus. If you want it to ride like a Lexus then you should not lower it much or at all and do not go with a large rim and a low profile tire.
Old Apr 29, 2006 | 05:33 PM
M-Flo's Avatar
I would recommend Raamat or Second Skin Damplifier as a sound deadener. Both are buytl based and considerably cheaper than Dynamat extreme.
To properly deaden the xA, you'll need to deaden the floor and hatch area, doors, and the wheel wells. This will deaden most of the road noise. You'll probably need around 150-200 sq feet of mat, and a polyurethane undercoating spray for the wheel wells.
For a more quieter ride, you can get a second layer of acoustical foam dampener to enhance the mat.
Old Apr 29, 2006 | 06:26 PM
I knew I had seen a pretty good one somewhere. Here it is.
http://xatuner.com/board/viewtopic.php?t=74
Old Apr 29, 2006 | 11:45 PM
Master's Avatar
thanks for the help guys.... yea i wanted it to be super quiet...i'm ok with the firm ride of lowered and larger wheels ;)
Old Apr 29, 2006 | 11:54 PM
Master's Avatar
Where can i get acoustical foam dampener mats at?
and some polyurethane undercoating spray?
you guys rock!
Old Apr 30, 2006 | 12:17 AM
Max's Avatar
Max
I love my eDead. The hatch in my xB made the most difference of all the panels I deadened.
Old Apr 30, 2006 | 12:33 AM
M-Flo's Avatar
Second skin and Raamat both sell versions of acoustical foam dampeners.
http://www.secondskinaudio.com/
http://www.raamaudio.com/
For the undercoating spray, you can grab it at any hardware store. The part number is MMM-08881, 3M rubberized aerosol undercoating spray. They work much better at absorbing sound than regular bedlining spray.
I would not recommend asphault deadeners like eDead. While they make great roofing insulation, they're just not designed for the automobile environment.
Old Apr 30, 2006 | 12:54 AM
Max's Avatar
Max
Um. Wow.
Old Apr 30, 2006 | 01:32 AM
hum, i don't know but the audio guys and a lot of Scion peeps swear by it.
Old Apr 30, 2006 | 02:31 AM
M-Flo's Avatar
It's not suprising. Asphault deadeners are just not suited for the automobile environment due to poor heat tolerance.
Take my advice however you want it though. eDead is a very cheap and affordable way to deaden your car, but so is Peal&Seal (Asphault based roofing) which is generally the same material but considerably cheaper. (granted neither of which I would put in my xA)
Butyl based deadeners such as Second Skin Damplifier, Dynamat eXtreme, and Raamat are superior in almost every way.
Old Apr 30, 2006 | 02:49 AM
H8me's Avatar
lets see here the idea behind sound deadners is to add weight to an object the more an heaver an object is the less
likely it is to vibrate and transfer noise any metrial that adds mass will do
two thing to keep in mind
1. how well will it stick. if it does not stick it does no good
2. can it put off toxic fumes. things used for roofing? i dont think i would take that chance.
Old Apr 30, 2006 | 03:28 AM
tanakasan's Avatar
FYI, eDead v1SE2 is butyl based, not asphalt.
I just did my doors, hatch and entire rear section. Costs a lot less than other comparable deadeners. What a difference! Lots quieter, doors sound and feel solid. No more tinny "clink" when the doors lock. If the door handle is let go and allowed to snap back, here is no annoying hollow tincan sound. Just a solid thunk.
I did it for my sound system, but even just for quieting cabin and highway noise, it is the best upgrade I have done yet. BTW, it sticks like a ****. No heat gun needed.
Don't get the older v1...it is asphalt.
Old Apr 30, 2006 | 04:01 AM
M-Flo's Avatar
Which is also a relatively new product. Their original eDead V1 (still selling) and eDead V1SE (studio edition...) were both asphalt based, just like peal and seal.
I'm not knocking on eDead, just the fact that asphalt has no place in our cars other than beneath the tires~
If you plan to deaden your car, do it properly!
Old Apr 30, 2006 | 04:27 AM
tanakasan's Avatar
^^ x2!!
Just get the right eDead...no stinky asphalt in our rides.
Old Apr 30, 2006 | 05:52 AM
Master's Avatar
^^^ good thing i checked this thread...i was about to buy the stuff on ebay.
where can i get this edead v2 at with a great price?
THANKS!
Old Apr 30, 2006 | 11:23 AM
kkawana's Avatar
http://ads.scionlife.com/adclick.php...om%2Fscion.php
ok thats a long link to get there (happend to bave a eDead banner next to the quick reply box) and i'm pretty sure theres a code for 20% off for SL members... tho the code escapes me at the moment
