hard wire a radar detector
Old May 2, 2006 | 01:01 AM
422sciontologist's Avatar
Default hard wire a radar detector
I have run the wires to the fuse terminal near the hood release. Where can I connect them to get power?
Old May 2, 2006 | 01:05 AM
jwaggz82's Avatar
cig lighter
Old May 2, 2006 | 03:43 AM
illiniguy's Avatar
I tapped the ACC fuse in the fuse box under the drivers side of the dash
Old May 2, 2006 | 10:28 AM
Did you just put the radar detector wire along one leg of the fuse?
Old May 2, 2006 | 03:05 PM
illiniguy's Avatar
Well i was lazy and used a mini fuse tapper so that I can use that fuse for anything esle I need in teh future. They have the fuse tappers at any auto parts store
Old May 5, 2006 | 02:10 AM
monkeyMojo's Avatar
I wired mine into the power mirror switch.
Old May 5, 2006 | 02:58 AM
tikbhoy's Avatar
you can wire it anywhere you want, its 12v
first figure out what fuse the radar detector is rated. and make sure you have a light tester. buy 1 inline fuse, 2 wire taps and electrical tape.
Old May 6, 2006 | 03:25 AM
Phixeus's Avatar
^ ditto. i pulled my extra 12v plug out of my center storage box and pluged my radar detector into it and ran the wire under the center console across the under side of the dash, up the a piller and under the head liner to the driver side visor! works great and is pretty well hidden!
Old May 8, 2006 | 01:32 PM
agmech's Avatar
Hey phixeus, could you post some pics? or I can PM with my e-mail and you can send them that way?? Would like to see your setup, thinking of doing something very similar or exactly the same as you. Thanks
Old May 8, 2006 | 02:22 PM
nyr197's Avatar
Wired mine to the sunroof controls, that way it's mounted high and next to my rearview mirror.
Old May 8, 2006 | 11:40 PM
agmech's Avatar
I see some people going with a high mount and others going with a loew mount. I've heard that mounting low is best for the performance of the detector. Those of you mounting high, is it because you heard that it performs better that way or is a style thing and you think it looks better?? Just curious really
Old May 9, 2006 | 02:14 AM
illiniguy's Avatar
High mount is better for perfmance for all bands, except laser. thats why mine is mounted high. Also the way i have mine mounted it is less detectable from outside the vehicle by an officer.
Old May 9, 2006 | 03:18 AM
agmech's Avatar
where did you get your info on high mount being better? not trying to be a D^$K, just curious. I like to do my homework before going into anything
Old May 9, 2006 | 03:37 AM
zucc's Avatar
umm i am under the impression that radar is better down low but is still good high, and laser is high mount if you want it low then expect to lose your laser.
pic of my setup
Old May 9, 2006 | 03:59 AM
ThePerchik's Avatar
Valentine owners manual and lots of google sources clearly state that it should be as high as possible.
Old May 9, 2006 | 04:42 AM
yellot00tr's Avatar
read this thing from radarbusters:
http://www.radarbusters.com/support/...detector/2.asp
Old May 9, 2006 | 11:11 AM
If you mount the detector low low, wiper blades can interfere with radar; too high and the windshield tint can interfere with laser.
Old May 9, 2006 | 03:42 PM
agmech's Avatar
I ask because I bought the BEL Rx65 and on radarroy or something I heard (and from others on here) that you want to mount it low. Well, I guess I'll just wait for mine to get here and read the manual.
Old May 9, 2006 | 03:50 PM
NoLimitzBuilt's Avatar
Team No Limitz
You can tap into any 12 volt wire. I would try and find one that turns on and off with the igntion. That way the RD dont stay on all the time.
If you want the best set up for a RD. Then get the one where the sensors moung front and rear and give you LEDs inside the car. I have done a couple of them. They are not cheap by any means though.
Old May 9, 2006 | 03:53 PM
agmech's Avatar
that's the thing, im usually willing to pay for a better product, but I don't THAT kind of money right now...but I do hear they are the best
