newb when it comes to wheels
Old May 4, 2006 | 05:41 PM
TheCor's Avatar
Default newb when it comes to wheels
im planning on ordering a set of 15" wheels for the xA pretty soon, and want to use the stock tires, atleast for the time being, so my questions are:
I know i can use a 15x7 wheel, and even s t r e t c h to a 15x8, but will a 15x6.5 work as well?
And, what offset do I need? i assume its a 4x100 hole pattern? but i want to make sure, these are the wheels im looking at - Rota Flight (anthracite with silver lip)
http://www.rotawheels.com/wheels.php
the specs are included there, do those have the correct specs for the xA and its stock tires??
thanks!!
Old May 4, 2006 | 08:18 PM
RTon20s's Avatar
The +35/+38 will work fine with no issue. The +18 would likely work great in the rear and be completely flush. In the front the +18 might stick out just a little bit. Some of the guys running low offset may know exactly where they would sit. You may want to get a set of small flares if you go with a +18. Then you would definitely want to get some spacers for the rear as well.
You could always go with a staggered set up as well, running +35/+38 in the front and +18 in the rear. A 10mm spacer for the front would probably work well with this set up as well.
Good Luck.
Old May 4, 2006 | 10:15 PM
Max's Avatar
Max
I am running OE tires and Rota Slipstreams in 15x6.5. No problems.
Old May 4, 2006 | 10:53 PM
hotbox05's Avatar
oe tires will streth to fit an 8 but it's a damn large stretch. lol
Old May 5, 2006 | 12:34 AM
Max's Avatar
Max
That's not what he was asking.
Old May 5, 2006 | 12:40 AM
hotbox05's Avatar
thanx for making me look dumb. lol
and yes as max had said before that will work fine.
Old May 5, 2006 | 12:47 AM
phatcyclist's Avatar
I ran 15x6.5 inch wheels for a while with my stock tires. they worked fine. the inch wider rim gives the tires a bit more regidity (they need it). I would say, keep with a 35-42 offset, save your suspension components.
Old May 5, 2006 | 01:23 AM
TheCor's Avatar
awesome, thanks for the suggestions, im 99% sure im gonna go with the Rota Flights in royal gunmetal, should look great on the black xA
evolving_machine
Oct 21, 2023 01:16 PM
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
EcoxA
Mar 18, 2015 03:45 PM
GoodVibes
Mar 3, 2015 09:47 PM
