View Full Version : Longer Wheel Studs
superfreestyle
05-04-2006, 08:29 PM
I want to put 10mm OTG spacers all the way around but i need studs that are 10mm longer..... what studs will work????
lppro-xb
05-05-2006, 01:47 AM
how long r the stock ones?
superfreestyle
05-05-2006, 02:34 AM
not sure
Chapelle
05-05-2006, 03:29 AM
i've heard that mid 1990s land cruiser studs will do the job but i haven't confirmed it myself. on a side note though, why don't you get the hub spacers for the rear? you'll get your 10mm and you wouldn't need longer studs.
- Dustin
superfreestyle
05-05-2006, 03:33 AM
- Dustin
already have them.... i'm having clearance problems with new pads on the front... i need to change them but when i do the floating calipers hit the rim.... so i just figured to keep it even front to back since it is now with the OTG hub shims
sciong
05-05-2006, 01:37 PM
You can get Weapon-R extended wheel studs but they look to be more than 10mm longer than the stock ones. You'll either have to get open end lugs or you could grind the studs to make them shorter.
http://www.eautoworks.com/html/ORD-1-1-1-24154.cfm
superfreestyle
05-05-2006, 02:03 PM
those look extremely long... im trying to go with a toyota product for safetly reasons
superfreestyle
05-06-2006, 10:47 PM
stockers are as follows:
Front: 12x1.5 40mm
Rear: 12x1.5 37mm
