Soupy_TC
05-09-2006, 01:35 PM
hey all i'm in a bit of a jam.... i was taking my 10" out of my tc last nite and wired up a new bazooka 10" that is designed for the tc... well when all said and done my "all auto" power window don't work.. they only work if i hold the button down on that particular door.. for example passenger window can only be opened by buttton on passenger door... any ideas on what the hell i did wrong please let me know... thanks
NoLimitzBuilt
05-09-2006, 01:54 PM
it is super easy to fix. Let me see if I can find that post on it.
resetting the power windows resetting the power moon roof
step 1 turn the key in the ignition to 'on'. step 1 turn the key in the ignition to 'on'.
step 2 on the driver's side control, push down (do not use 'one-touch' down) the power window switch for the driver's side window and lower the window halfway. step 2 keep pressing the sliding roof switch to the close side until the center glass panel is fully closed.
step 3 pull up (do not use 'one-touch' up) the power window switch until the window closes and hold the switch for *at least* one second. step 3 if the switch remains pressed for approximately two more seconds after the panel is fully closed, the sliding roof ECU memorizes the fully closed position.
step 4 repeat these steps for the passenger side window on the passenger door window control. the windows should now open and close like they should. step 4 the center panel glass returns in the open direction a little and informs that initialization is complete."
Soupy_TC
05-09-2006, 03:28 PM
oh my god!!!!! i can't believe how simple it was... i'm sorry for posting that now..... you guys rule :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
It never hurts to ask.. you would of stressed on this for a longer time frame.
instead of finding out a easy answer!
there are some other threads for this so in the future see if you can try searching for it first so we don't have any super mods attacking us ;-)
