19's on an xB Camber?
Old May 9, 2006 | 05:02 PM
LouKY05XB's Avatar
Default 19's on an xB Camber?
Ok who has 19's on their xB? i plan on buying some and want to know any rubbing/fitment problems.
Also i hear this talk about bigger rims needs camber adjustment. On a 42 offset how do i fix this? where do i buy the part? is it hard to install?
Any help is appreciated
Old May 11, 2006 | 06:17 AM
aireck's Avatar
i rolled on 19x7.5 with 215/35 size tires...
on DF210's and i never rubbed even with a fully loaded xB...
you'll be ok .. you can add OTG shims in the back to bring out the wheel to match the front.
Old May 11, 2006 | 12:13 PM
LouKY05XB's Avatar
hey man i appreciate that info so no rubbing up front on turns either? im running trd springs. how low did your springs bring you? where can i get OTG Shims? can the alingnment shop do this as i plan on having it alingned after install or is it easier/cheaper for me to do it(the shims)?
thanks again
rodge
Old May 11, 2006 | 03:37 PM
RTon20s's Avatar
If you have the right tools and decent mechanical ability the OTG hub shims are pretty easy to install. I did it at night with shop lights in my parents driveway while visiting. It is nice if you have a torque wrench so you can torque everything to spec, but not necessary. I don't recall if the kit included torque specs, but you can look them up online for the bolt size.
Old May 14, 2006 | 10:18 PM
JBIBxB's Avatar
Im rollin 19x7.5's on a 215/35 and i have a bit of a rubbing issue in the front but had my over weight friends in the back last night and had no rubbing bacak there, when i hit big bumps is when i notice the front but it'll roll
Old May 14, 2006 | 10:21 PM
eight08customs's Avatar
I had AXIS mod 7s 19x8 stagered no rubbling plus i havd the OTG shims in the rear..
Darrenohooligan
Sep 26, 2015 07:21 AM
scionhawaii
Sep 1, 2015 08:14 PM
domincnTC
Aug 4, 2015 01:47 PM
Subaru86
Jul 31, 2015 04:33 AM
Subaru86
Jul 31, 2015 04:00 AM
