17X8.5 w/ 48mm offset. What size tire?
http://www.rims-n-tires.com/rt_specs.jsp
^Try that out. With a 48 offest you should be careful about a rubbing issue on the inside (maybe ino the suspension).
Paul G.
Paul G.
sounds like you will have issues with rubbing inside the wheel well.. but you did say 38 so it mught not be a prob with your tires but 245??? Just sounds off to me.. maybe since thay are 17's that will help you... oh well... good luck, and post some pics when you are done...
Paul G.
Paul G.
Paul G.
Paul G.
The best think to do is to look at the actual tire specs online or call the manufacture. Compare that information with the link I provided and see if things differ much.
Paul G.
DerK
Scion tC 1G Wheel & Tire
Nov 20, 2007 01:28 PM
itza2dal
Aug 4, 2006 05:48 PM
