Anyone change the spring rate on the SS-Ps??
Old May 12, 2006 | 07:27 PM
Harmonic_tC's Avatar
Default Anyone change the spring rate on the SS-Ps??
after driving on them for a few days the rear just seems too harsh. I was thinking of swapping in a 6G spring instead of the 10G that tein sends. I was thinking of leaving the fronts the same which is a 7G spring.
Has anyone changed them?? What did you change them too and what were the results???
Thanks!!
Old May 12, 2006 | 10:18 PM
2redgerm6's Avatar
my suggestion to you is to call tien and ask for suggestions there tech is good. when i had tiens on my corolla they said it was ok to go 1 or 2 kg softer but no more without revalveing the shocks. also you should not just change the back or front without changeing the other as it will throw the balance of the car. CALL TIEN!!
Old May 12, 2006 | 11:57 PM
I may call tein, i was just curious if others on this board had changed them...
Old May 18, 2006 | 06:44 AM
tc913's Avatar
I've been thinking about the samething too. I got Basics and the rear is harsh, so I was thinking about chaging the front to 6kg and the rear to 8kg. Ive talked to Tein about it and they say it's ok if you change +/- 2 kg w/out revalving the shocks and they said that it would cost 100 bucks per damper.
Old May 18, 2006 | 03:09 PM
$100 per damper? esh, it sadm$50 per coil on thier site for standardized coils. oh well, im sorta getting used to it now
Old May 19, 2006 | 06:20 AM
tc913's Avatar
oh that is for re-valving the dampers.
ganyon
12
Mar 31, 2015 03:58 AM
808xBguy
Jan 10, 2015 02:21 AM
fluxingnation
Dec 26, 2014 04:28 PM
ScionVan
11
Dec 2, 2003 09:37 PM
hydrogen
Oct 29, 2003 04:58 AM
