Couple of quick Spring install questions......
Old May 20, 2006 | 03:58 AM
TwztdXB's Avatar
Default Couple of quick Spring install questions......
When installing the rear springs , which way do they go. I"ve seen two different install guides and they say to do if different ways. Do the bigger coils go on the top or bottom? I have Tein S-techs if it makes a difference. And one more questions, when I was installing my front springs I must have been in a hurry but I forgot to cut my bump stops like the instructions said too. Is this something that must be done or will they be ok if I don't? Thanks for any help it is appreciated.
Old May 20, 2006 | 04:03 AM
Max's Avatar
Max
Mine said to install with the closer coils on the bottom.
I did install mine without cutting the bump stops, but found my error and took everything back off and cut them.
I have Hotchkis.
Old May 20, 2006 | 05:22 AM
btodailly's Avatar
i didnt cut anything for the rear springs.... and also my rear springs have the fatter bottom on the bottom if i remember correctly... follow what the stock springs show
Old May 20, 2006 | 06:00 AM
khaye's Avatar
cutting the bump stop will allow strut to have a longer travel so yes take them off and cut them. as for the rear spring it's gonna be the same compression either ways. the only thing is that you have to make sure it fits on the bottom groove and the top rubber piece
Old May 20, 2006 | 10:47 AM
ProshopXB's Avatar
My H-techs had writting on them, to let you know what was up and down. I had the same question when i did mine and looked at the spring and saw the writting. I would hope the S's have the same thing.
Old May 20, 2006 | 04:59 PM
TwztdXB's Avatar
Yeah they had writing on them, Thats how I installed them so you could read the Tein logo, So I guess the rears are ok but on my next day off I'm going to have to take the fronts back off and cut those bumpstops. Thanks for the help guys
scionlife
10
Mar 1, 2016 09:14 PM
bBOXD
28
Dec 7, 2003 07:08 PM
randode
18
Nov 19, 2003 03:37 PM
rolex87
Oct 13, 2003 05:48 AM
randode
Sep 30, 2003 10:50 PM
