View Full Version : Tried searching, but can't find exact answer....19" Whe
AleXb
06-15-2004, 02:49 PM
I am so lost.... What do i have to do in order to not worry about rubbing at all with 19" rims?.... I plan on using Tanabe DF210 springs for a 2" or more drop and the 5Zigen 19" Hyper 5ZR's.....
-Should i run 19x8 front and back?..... or staggered 19x7.5 front and 19x8 rear?...
-Should i run 19x7.5 front and back so rubiing isn't an issue?...
-What size tires to run with those three setups?.... so i don't rub while turning all the way.....
-What Offset to run?
I am pickin up these wheels in like a day or two so quick responses would be highly appreciated....Thanx soooo much guys
-Alex B.
aero2424
06-15-2004, 08:44 PM
I'm in the same boat...
19x8 w/215s needs what offset? I've seen 35,40,42, 45
or..
19x7.5 needs?
XBOXED
06-15-2004, 09:31 PM
if you run 19x8 run a 40-42 offset and if you run 19x7.5 run 40 offset
as for tires.... dont go larger run 215/35/19 thats a great size that will give minimal rub
wickedchimp
06-16-2004, 01:37 AM
So 19x8 with 45 offset is too much?
