Newbee needs to install a Code-Alarm on a '06 Xa.Please Help
Old May 25, 2006 | 08:59 PM
jaminglenn's Avatar
Default Newbee needs to install a Code-Alarm on a '06 Xa.Please Help
Please help. I need a wiring diagram at the very least. I am pretty good at figuring things out myself, but it would be much easier if I had a little help from someone who has done it before. The alarm I am installing is the Code-Alarm CA670, So if anyone knows where I can find a wire diagram for the '06 Scion Xa I would really really really appreciate it. Thanks!
Old May 26, 2006 | 04:18 AM
FoDoToaster's Avatar
Can I give you some advice? Chuck the Code Alarm in the trash. Sorry to say, but you'll be doing it in a few weeks if you install it. Throw a few more down and get something by DEI. Viper, Python, Clifford, whatever. It's the only thing I'd put on my own car, and I've been installing for 6 years. Before Circuit City dropped Code Alarm, every other one was bad right out of the box.
Old May 26, 2006 | 12:36 PM
H8me's Avatar
i would rather see u with a DEI product too.
DIRECTWIRE™ WIRING INFORMATION - SCION / XA / 2006 / Remote Start
[PRINT THIS PAGE]
12volts wht/blue (50A), wht/red (15A) + ignition harness
Starter black + ignition harness
Second Starter N/A
Ignition black/red + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory white/blue + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Power Lock brown/yellow - driver kick, 18 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock blue/yellow to yellow/black - driver kick, 18 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder. Unlock requires a double pulse.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is green/black (-) in the passenger kick in a 14 pin plug.
Lock Motor blue/white 5wi driver kick, 13 pin plug
Unlock Motor blue/black to yellow/green 5wi driver kick, 13 pin plug
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Hazards green/orange - hazard switch
Turn Signal(L) green/black + top of fuse box, 13 pin plug
Turn Signal(R) green/yellow + top of fuse box, 13 pin plug
Reverse Light red/black + top of fuse box, 9 pin plug
Door Trigger red/blue - top of fuse box, 9 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer black ac data link conn below fuse box, pin 9
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake yellow/red - top of fuse box, gray 11 pin plug
Horn Trigger white/red - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old May 26, 2006 | 04:30 PM
jaminglenn's Avatar
Ok, well unfortunately I have already purchased the thing. I am happy to say that I did pay a considerabley less amount for it though. I guess I can just cross my fingers nad hope it is good out of the box, Do ya'll have any suggestions on where to find a wiring diagram for my 2006 Xa? If I had heard your advice prior to purchasing it I most certainly would have checked out the DEI, but to tell you the truth I had never heard of it. Thanks
Old May 26, 2006 | 08:05 PM
Forklift's Avatar
you never hear about DEI as they are the parent company to Viper, Clifford, Python, Orion, West Coast Customs(the video and audio, not the place), A/D/S, PPI, WASP, Hornet, etc
Old May 27, 2006 | 03:28 AM
jaminglenn's Avatar
ahh, well I checked out a few of their alarms and to me it seems like this is a better alarm. Although I am certain that most people know more about alarms than I do. Is it that most of them are bad out of the box or is it just a bad alarm all the way around? The alarm I got seems to have alot of good features. And I am still determined to try to install it myself so any....ANY help is greatly appreciated. Maybe in the form of a wire diagram....thanks
Old May 27, 2006 | 01:10 PM
H8me's Avatar
its not about featurtes it is about quality of product
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
