lowering voids warranty
Old May 25, 2006 | 10:00 PM
sammyj's Avatar
Default lowering voids warranty
Is it true if you lower you ride and dont use TRD springs it will void your warranty?
Old May 25, 2006 | 10:06 PM
reckless's Avatar
void is NOT the word to use. HONOR your warranty for your suspension they will NOT if you use non-TRD springs, something goes wrong, and if service can trace the fault to the non-TRD springs.
Are you sure you searched for this topic before you posted....?
Old May 25, 2006 | 10:09 PM
ack154's Avatar
^ I'm not sure if that's the best wording for it either. At least the "non-TRD" part.
Here's a scenario that should explain it.
If you install springs on your car (Hotchkis for example), it will lower it. But you may still be using your OEM shocks/struts. If your OEM shocks or struts blow out, they could likely determine it was the non-OEM springs that were the direct cause of the problem. So they would not replace your shocks/struts under warranty.
There is a thread in the Maintenance and Car Care forum stickied for this. I suggest you read it.
NonStopTuning
Jun 29, 2015 07:42 PM
nightfox915
Apr 17, 2015 07:06 PM
ScionDP
Mar 13, 2015 10:16 PM
kidkamel
14
Jan 18, 2008 11:39 PM
morph1119
Dec 24, 2003 07:38 PM
