New eD setup need advice on wireing
Hello,
I just bought 2 NINe.2 amps, a set of eDi 6000s, and an 11Ov.2 sub.
I am a beginer with car audio though and am unsure of what all I need for wiring...
any advice on this matter would be greatly appreciated...
cheers-
-Tyler
cheers-
-Tyler
You will need minimum of 1 x 8ga power wire (red) to each. Or 1 x 4ga to a distro block then split to 2 x 8ga. Be sure to fuse the power lead, within 1 foot of the battery with the correct amperage fuse! Very important! Grounds (black) sized same or larger than power and as short as possible. Less than a foot is good.
Also 2 x stereo RCA (signal to amps) cables and speaker wire. For 6000's, 18ga OK if short runs, 16/14ga is better. I like minimum 12/10ga for the subs. Finally some blue 16/18ga for the remote turn on wire.
Heres eD recommended for 2 amps:
http://edesignaudio.com/wire_product.php?productid=252
Check eBay if you are on a budget.
Some crimps or solder, heat shrink tubing or tape (uggh!) and zip ties to keep it neat. Buy enough wire, it sucks to end up too short. Less (none) splices the better!
Check out the wiring diagram @ elemental, depends if you bought a D2 or D4 Ov2:
http://www.edesignaudio.com/wiring.php
Hopefully, you got a D2.
yes, I did get a dual 2ohm :D
thanks for all the advice...I have general sense of what I need, I just didnt want to be in the middle of things and not have something I didnt realize I need..
I am on a budget, so ill check around.
thanks for the advice :D
-Tyler
-Tyler
yeah, I think you pretty much covered it good....Im also going to talk to my dad about it tomorrow...hes old school... :D]\
ill post pics of it when its all done...all I have left to buy is the Head Unit, wiring, and materials to build an enclosure....gonna build a sub box from MDF and fiberglass either some kick panels or pillar pods for the components...
my06tc
Jun 25, 2015 12:18 AM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
2002cbr600f4i
Dec 6, 2003 02:01 AM
