jocappy
06-16-2004, 04:02 PM
The size and brand are, 215 35 R19 Falken Brand? 10K miles 20K miles, 30k miles??? Joe
View Full Version : How long will these tires last??? jocappy 06-16-2004, 04:02 PM The size and brand are, 215 35 R19 Falken Brand? 10K miles 20K miles, 30k miles??? Joe JDMxB 06-16-2004, 04:06 PM It depends on A. Tire Model--not just brand. B. Road Conditions. C. Your driving style. George 06-16-2004, 08:42 PM The size and brand are, 215 35 R19 Falken Brand? 10K miles 20K miles, 30k miles??? Joe The treadwear rating is 360, the same as the OEM tires. They should last about as long as the OEM tires did. George TRF_USA 06-16-2004, 09:18 PM I am not tire expert... But I think even the tread wear is 360... 15,16,17,18,19 inches does make different H, W, Z rated tires also make difference even they are same tread wear How wide of the tire will also make difference too Temperature will make difference as well Your car condition will also make difference When your car is lowered, tire wear from inside cause of the off camber And it will cut down your tire life So your tires might look brand new outside but inside is all flat You cannot compare the wear of the tire with your stock tires Unless they are the same exact tires |
