Almost done with my in console radio / gauge mount !
Old May 27, 2006 | 10:04 PM
Garage1217's Avatar
Default Almost done with my in console radio / gauge mount !
Had this idea for a long time and finally had a day without kids to do it. I know some others on here have done it and man it looks great so far! I even got the carbon fiber to take the shape of the center consoles slight curve...
Bent a long peice of aluminum scrap into an L to brace it across the body and stuck it down with 15K psi epoxy, and damn this baby is strong! I then made little arms to push hard onto the carbon and hold it in place. Used the screws that originally held on the door assembly to hold the arms and secure the face. I then used lots of black silicone adhesive all the way around it further brace it! This baby is tough! And it is only going to hold three gauges *LOL*!!! The deck will be held in by the oem deck mounts re-drilled. Anyways hope it gives some of you idea's! Took awhile to make... as I was figuring out what to do as I went along with it haha.
Best part is, All I have to do is use a blade to cut the silicone away and remove the 4 screws if I ever want to take it out and return it back to stock! I did not have to modify any oem parts!
Old May 27, 2006 | 10:17 PM
Garage1217's Avatar
More pics to come later when the gauges are all mounted up and the deck is aligned! Should have gauges in late this week "boost -30 - 20 psi / oil pressure / pyro
Old May 28, 2006 | 12:36 AM
Garage1217's Avatar
Ok got it installed! I just stuck some mock up gauges I have laying around in so you can see what it will look like. I understand after some pm's that most non installers cannot visualize an item installed haha... so anyways here ya go! "Bottom pic is with the flash on so that it shows off the carbon...."
Old May 28, 2006 | 02:23 AM
Tecrun19's Avatar
That is cool. Even cooler you did it by yourself !!!
Old May 28, 2006 | 02:25 AM
Garage1217's Avatar
I do all my work myself, well 99.999% of it haha. Had a local cool dood named RJ work over the gauges because he has done so many..
Old May 28, 2006 | 03:52 AM
rj's Avatar
rj
Who me?
Looking good on that dash! Makes me wonder if you did car audio for a while?
Old May 28, 2006 | 03:54 AM
Garage1217's Avatar
Haha Yeah may have done an install or two before... And hell yeah! Your the LED master!
RJ does great work people, you need gauges done, contact him!
Old May 28, 2006 | 04:01 AM
Magnus213's Avatar
That's a great look, congrats on the good turnout.
Old May 28, 2006 | 06:40 AM
tom0613's Avatar
that ____ is hot nice
Old May 28, 2006 | 07:54 AM
yellowxboy's Avatar
looks really nice and clean. arent you going to miss your cover though? i know i would!
Old May 28, 2006 | 08:01 AM
islandromeo81's Avatar
sweet install i like it
Old May 28, 2006 | 06:18 PM
Garage1217's Avatar
Naw, I could not use the door anyways with that deck. The **** stuck out to far and I could not recess the deck any further because of the way the display extends out. If I did recess it, the door would hit it's own trim ring and not allow a cd to eject. So the door was not functional and was just a hood anyways!
Old May 29, 2006 | 06:43 AM
HighlanderMac's Avatar
Dude that is freakin AWSOME..
Is there any way you could do that, but opposite? What I mean is, how hard would it be to have the gauges on top and the H/U on bottom?
Old May 29, 2006 | 06:45 AM
Garage1217's Avatar
Same amount of work, Total pain in the ****... I just wanted them this way I thought about doing it the opposite though. Took a few to make the final decision.
Old May 29, 2006 | 07:40 AM
I am just wondering because I may look into doing it.. It looks AWSOME!!
Old May 29, 2006 | 07:45 AM
Garage1217's Avatar
Thanks man just be sure to measure twice or more haha. The fit is very tight between the console, bottom of the gauges, gauges to deck, deck to top of console...
Old May 29, 2006 | 07:50 AM
Garage1217's Avatar
Got a new cam, here is a better pic
Old May 30, 2006 | 02:53 AM
jwaggz82's Avatar
parts like this i can see you making some $$ if you made a few dozen of these.
Old May 30, 2006 | 03:02 AM
Garage1217's Avatar
uh.... not gonna happen *LOL* Was to much of a pain. Thanks though!
Old May 30, 2006 | 03:06 AM
jwaggz82's Avatar
hehe. figured ide give it a shot.
