would this fit?
Old May 30, 2006 | 06:15 AM
smn's Avatar
smn
Default would this fit?
my friend is selling his set of ssr professors and i really love his rims but i was wondering if they would fit the tC. Here's the specs
18x8
5x100 bolt pattern
offset is +49
tires 225/40/18R
thanks for you time I really appreciate it
Old May 30, 2006 | 09:07 AM
SCION_X's Avatar
i do not believe that will fit. Our stock rims are +45 offset and 7.5 or is it 7 wide. a +49 offset and 8 wide rim might stick in way too much and scape your inner feder or run into your struts/shocks.. You could put a 5-10mm spacer on it so it will push it out.. Please correct me if i am worng guys.. I have been doing extensive research lately to make sure i wont have any probs of my own and i believe i am corret or atleast close enough to it to matter... Good Luck.
Old May 30, 2006 | 01:17 PM
smn's Avatar
smn
ahh i see i was thinking of offset was too high. thanks for the info tho.
Old May 30, 2006 | 05:20 PM
HKSpeed's Avatar
that setup will sit inwards 16mm and poke outwards 8mm compared to stock.
H&R makes 5,15,20,25mm spacers. no 10mm. a 15mm up front and 20mm in the rear will makes those fit really clean and flush, without rubbing.
I personally would use 20mm front, 25mm rear and deal with the rubbing for a better looking stance. lol.
SpaceCaptain
May 11, 2015 06:24 PM
KTamAK187
Apr 15, 2015 10:08 PM
HotLavaDestiny
Apr 10, 2015 05:10 PM
skruff
Apr 6, 2015 06:34 PM
