Best springs for a 2" drop
Old May 30, 2006 | 07:47 PM
Cyrus's Avatar
ScionERA
Default Best springs for a 2" drop
I'm gettin my Xb today, I will be putting 18x7.5 rims on it. I am looking for real feedback on which springs are truly better and wont kill my suspension, and am I looking for any trouble running 215/35-18 with the drop. Thanx again all.
Old May 30, 2006 | 08:15 PM
keoki's Avatar
goldlines are good! that's what i got and a lot of other peeps have them also. I recommend getting some OTG(onetongarage) spacers/shims for da rear wheels. 215/35-18 are fine with a 2" drop!
Old May 30, 2006 | 08:23 PM
Cyrus's Avatar
ScionERA
the flat spacers ? to bring the tires flush ? or to cut any rubbing out ?
would 40's be to tall, would the ride be any better ?
Old May 30, 2006 | 08:47 PM
keoki's Avatar
to bring da tires flush. most peeps use 35's and your better off with 35's anyways. check out our forum desert & salt!
check this link out! http://www.onetongarage.com/products...him/index.html
Old May 30, 2006 | 09:05 PM
RMS's Avatar
RMS
Check this out for springs
https://www.scionlife.com/forums/viewtopic.php?t=50481
Check out for tires/wheels
https://www.scionlife.com/forums/viewtopic.php?t=348
and most of all, use the "search" button
Happy researching, it took me awhile to figure out what I wanted.
Old May 30, 2006 | 09:54 PM
RTon20s's Avatar
I would highly recommend the Tanabe DF210 springs for a 2" drop.
Also, before you go buying spacers for your wheels, post up the offset specs and we will help you determine of they are actually necessary.
Old May 31, 2006 | 05:08 AM
TJ's Avatar
TJ
Nah i suggest the Megan Racing springs. go for the higher spring rate with a little raked look.
Old May 31, 2006 | 06:57 AM
Cyrus's Avatar
ScionERA
did research and checked previous info, but specs dont necessarily help, experience does. Thanx !
Old May 31, 2006 | 05:14 PM
IH8ONYU's Avatar
anyone know how to determine the offset? is there a stamp on the back that lets you know? i have the trd 5 spoke 19'' package and for the life of me i can not find out. I asked the dealer where i got the car, and damned if they knew!
Old Jun 1, 2006 | 01:05 AM
evilBOXevil's Avatar
I have Df210s (dropped 2" or more) and They are very comfortable to ride on. Spring rate is up only 15%, so it's not that big of a change over stock. Also, I'm riding on 18x7.5 rims with 215/35 tires. No spacers, no shims, and no rubbing at all.
Old Jun 1, 2006 | 04:59 AM
stick_1NZ's Avatar
^^^^ Same here. DF210s.
Old Jun 2, 2006 | 02:32 PM
trdsparks's Avatar
I can't tell a difference between the Hotchkis and the Goldline. They look exactly the same and if you measure them the drop is exactly the same. They both ride good but I like the Hotchkis spring better. Just my $0.02
Old Jun 2, 2006 | 03:53 PM
RTon20s's Avatar
Maybe because you sell Hotchkis, but not Goldline?
Old Jun 2, 2006 | 04:51 PM
Mooneyzs's Avatar
Team No Limitz
I would recommend Eibach Sportlines. It gives a great drop and the ride is awesome. the spring rate is alittle higher than goldlines so they are a little more agressive. I haven't had one complaint about them.
Old Jun 2, 2006 | 05:10 PM
trdsparks's Avatar
No not really. I just think they ride sligtly better.
danielv
Aug 26, 2015 07:14 PM
fcortez58
Jun 26, 2015 04:55 PM
ZachGtC14
Apr 17, 2015 10:53 AM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
kleecker
Dec 31, 2014 09:42 AM
