boost controller,and gauges need help
Old Jun 1, 2006 | 09:44 PM
tom0613's Avatar
Default boost controller,and gauges need help
i need help to wire a electric boost controller and some electric gauges. i am mounting gauges above the the radio on the dash and just wondering if i can use the factory harness that the radio is using and just connect the battery ignition and ground wires to it and just fuse all the wires except for the ground.
Old Jun 2, 2006 | 03:31 AM
deathbyc4's Avatar
You sure can. But I would recommend running a relay off the ACC line to allow for future mods. My Nexus guages are hooked up that way along with my Tcover. not much amperage increase but any more and I will convert it to a separate circuit so just the relay and the head unit are drawing current from the factory acc line. Just food for thought.
Old Jun 2, 2006 | 03:07 PM
tom0613's Avatar
thanks. i have tohook up the brain for the nexus gauges aboost controller and a wide band do u think that will still be ok
Old Jun 2, 2006 | 07:18 PM
deathbyc4's Avatar
I'd run the boost controller and wideband off of a different constant source than the radio, noise may affect the controller and wideband. But the ACC line should be fine.
BlackKnight
Sep 15, 2015 06:42 AM
my06tc
Jun 25, 2015 12:18 AM
knepart
Scion FR-S Forced Induction
Apr 25, 2015 02:48 PM
spawnconnery
Dec 18, 2014 08:38 PM
mattjk
121
Dec 22, 2004 10:49 AM
