Underhood Cathode Question
Old Jun 4, 2006 | 06:57 PM
MrMcNuggett's Avatar
Default Underhood Cathode Question
I put cathodes under my hood and they won't stick...they keep coming off and falling....My question is what is the best thing to use to stick them to the metal under the hood to keep them there permanently?
Old Jun 4, 2006 | 06:59 PM
Spr0ket's Avatar
Zip Ties. Not much else.
Old Jun 4, 2006 | 07:51 PM
How do you zip tie when there is not any where to tie to
Old Jun 4, 2006 | 07:54 PM
OldYeller's Avatar
I have not had a problem with my cathodes sticking. Did you prepare the surface before using the double stick tape? What type of tape are you using?
Old Jun 4, 2006 | 08:54 PM
cheXmiXB's Avatar
i use the strong double sitck tape that holds 5 lb. its by 3m you can get walmart...
Old Jun 4, 2006 | 09:09 PM
chadfo's Avatar
Get the good 3M grey double sided tape. It'll hold practically anything. Also wipe the area you are going to stick to with alcohol or some type of solvent to make sure it's clean.
Old Jun 5, 2006 | 04:33 AM
Spr0ket's Avatar
Hmm... nothing to zip tie them too... hmm...
I know! Holes in the hood! Bring out the drill!
J/K. Use the strong grey tape chad mentioned. It's usually covered with a red plastic. I've seen it used to put body kits on. Just make sure the stuff you get will hold up to the heat.
Old Jun 5, 2006 | 07:17 AM
surfcitylocal's Avatar
This stuff is awesome! You can get it at Lowe's, Home Depot, Pep Boys and Ace among others. I used it to mount all my cold cathodes in the engine compartment and have not had any problems at all. 3M Exterior Mounting Tape, Super-Strong, 5 Lb Capacity, Gray/Red Liner
Old Jun 7, 2006 | 08:21 PM
mushroomdreamer's Avatar
Default Dude............... SILICONE!!!!
prepare the area you want them to stick to, (make sure all the cathodes have silicone around them so they wont blow out when you put water on them) all you need is a small dab of silicone just use enough. put it in the area you want to mount them and hold the CC in place for awhile or you can use masking tape and let them set over night. (Next day) carefully remove the masking tape and no need for zip ties. Trust me i have three cathodes in my engine bay no problems yet.
Adhisive silicone - Auto zone
Old Jun 7, 2006 | 08:26 PM
Storm13's Avatar
I am also using the exterior adhesive double-sided tape for my underhood cathodes. It's held perfectly for 2 months so far.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
