windows
Old Jun 5, 2006 | 10:03 PM
zim6699's Avatar
Default windows
humm... my windows stoped working...
i was putting dynomat ion my doors and when i hooked wverything back up my back windows no nolger worked at all not from the back or from the front.
any1 else ever run into this problem...
Old Jun 6, 2006 | 03:04 AM
H8me's Avatar
check all the fuses and all the doors see if you forgot to plug something back in.
DIRECTWIRE™ WIRING INFORMATION - SCION / XB / 2006 / Accessory
[PRINT THIS PAGE]
12volts wht/blue (40A), wht/red (15A) + ignition harness
Ignition black + ignition harness
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Headlight black/white - headlight switch
Trunk/Hatch Release brown/yellow - driver kick, harness to rear
Notes: Meter this wire while opening the hatch from the handle on the rear hatch.
The hatch release motor wire is blue/yellow (+) in the driver kick, harness to rear.
Power Sliding Door N/A
Speed Sense purple/white radio harness
Wipers gray (L), black/red (H) + windshield wiper switch
LF Window up/dn red/blue - green/white A driver window switch in door
RF Window up/dn red/blue - green/white A driver kick, 9 pin plug
LR Window up/dn red/yellow - green/yellow A driver kick, 4 pin plug
RR Window up/dn red/black - green/black A driver kick, 4 pin plug
Sun Roof open/close N/A
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old Jun 10, 2006 | 04:17 AM
zim6699's Avatar
tried... the front passenger stoped working to for a sec this morning but then it started working again... all i did was unplug the driver side harness.... it shouldnot have done anything to the car...
Pack34
Scion tC 1G ICE & Interior
Sep 27, 2015 07:11 PM
SCGBox
Sep 23, 2015 03:29 PM
EVILDAVE
Sep 15, 2015 06:54 AM
prescottn
Sep 13, 2015 09:04 PM
BlingSlade
Sep 5, 2015 08:52 AM
