Daytime driving lights.....
Old Jun 6, 2006 | 03:18 PM
AleXb's Avatar
Default Daytime driving lights.....
Is there anyway to "give" the xB Daytime running lights? From my understanding, daytime running lights are simply the high-beams turned on, but they only recieve a low voltage thus keeping them on, but not blinding anyone.
I've always like the way that daytime running lights loooked, plus they are a great safety measure to take to ensure you are seen.
-AleXb.
Old Jun 6, 2006 | 03:23 PM
tC9o9's Avatar
what i plan to do is just take a 9005 HID 3000K kit and wire it up to the battery and to a switch.. however i have a tC so my set up will be a lil different
but the DRL(DAYTIME RUNNING LIGHTS) will be housed in the high beams, so basically i will lose my high beams, but i can use them via a switch..
im mot sure whether or not the xB has two housings for hi and lo or if its just one, you would know better
Old Jun 6, 2006 | 04:27 PM
TuningIsLife's Avatar
its a single bulb unit. Easiest way to give the xB DRLs is to wire up a relay.
https://www.scionlife.com/forums/viewtopic.php?t=5547
Old Jun 6, 2006 | 09:54 PM
AleXb's Avatar
im using projector headlights that use a separate low& high beam....
-AleXb.
Old Jun 6, 2006 | 09:57 PM
Yes, but it is also the same wire
There is a different wire coming off of your headlight switch for highbeams. I know I did this mod.
Old Jun 6, 2006 | 09:58 PM
bBlover's Avatar
Ah sounds interesting.
Old Jun 6, 2006 | 10:09 PM
AleXb's Avatar
is there a simple way to wire just the high beams on a lower voltage to give them the DRL appearance but get turned on only with the parking lights? And of course still maintain the ability to turn on the true high beams from the cockpit?
Old Jun 6, 2006 | 10:54 PM
Use a secondary switch plus ignition power plus a resistor.
Old Jun 6, 2006 | 11:11 PM
AleXb's Avatar
would it be possible to tap the high beam into the parking lights directly? Are the parking lights running at a lower voltage?
-AleXb.
Old Jun 6, 2006 | 11:18 PM
no. still 12v. Because it is a toyota there is no such thing as a lower voltage.
Old Jun 6, 2006 | 11:27 PM
TLRlive's Avatar
This is all pretty easy. You can split power from the parking lights, add a resistor and get the lower voltage. If you just want DRL without the parking lights you need power, resistor, and a relay to turn them on when the car is running.
Old Jun 7, 2006 | 06:06 PM
Scion_Lewisville's Avatar
You can buy the OEM bB heads...it has the driving lights.
-George
evolving_machine
Oct 21, 2023 01:16 PM
yoson13
Scion xA Aero & Exterior
13
Aug 29, 2015 11:12 PM
carid
Jan 8, 2015 11:33 AM
Besk_one
Nov 17, 2003 09:28 PM
TheRedBox
Oct 8, 2003 04:25 PM
