tC Short shifter purchase question
Old Jun 7, 2006 | 10:25 PM
jasper's Avatar
Default tC Short shifter purchase question
I was thinking of getting a short shifter from Ebay with the assembly together, but i saw most of the DIY post are getting out just the shifter and use the original assembly housing back. Since I can get the short shifter with the asembly, and it is just a direct bolt on, so why people want to do that extra work to remove the shifter from the assembly but not just replace the whole assembly? Are they different? Please help me out. Also, is the process be much more simpler if I use the after market assemly, since shift cables will be the only thing to remove?
Old Jun 7, 2006 | 10:37 PM
ichibansf's Avatar
Go ahead and try the ebay one. I'm sure everyone is curious as to how they are. Personally when it comes to an essential part like that I'd go with a respected name, which is why I installed a B&M.
ack154's Avatar
A ton of info here:
https://www.scionlife.com/forums/viewtopic.php?t=104874
Including info on the housing vs shifter rod. Read up!
Old Jun 7, 2006 | 10:43 PM
tml057's Avatar
Bingo... this is the reason people do not go with the full assembly. TRD is the only fully packaged (shifter and assembly) that I know of that appears to be of quality, but it's pricey.
I went with the B&M because I trust them, and I know of many people who have ran them with no problems. It may not be a direct swap, but if you have the tools and some common sense, it really is not a problem to install. Should take about 45 minutes (if you know what you're doing) to 2 hours (if it's your first time dealing with a shifter assembly) to install, including removing everything and putting it all back together.
Old Jun 7, 2006 | 10:47 PM
jasper's Avatar
Originally Posted by ack154
A ton of info here:
thanks a lot!
Old Jun 7, 2006 | 10:49 PM
ichibansf's Avatar
Yup, took me about an hour and two beers. Go invest in a dremel or clone to cut that lock washer thing off.
Old Jun 7, 2006 | 10:54 PM
SquallLHeart's Avatar
hmm.. in my opinion... i think it's easier and better to replace just the shaft.
that whole assembly thing.. hmm.. esp.. that ebay one... really iffy.
Old Jun 7, 2006 | 10:57 PM
cdubber9's Avatar
Go with just the shifter, their cheaper and the install is not hard, plus you don't don't have to disconnect the shift cables from the assembly. I went with the B&M as well for the same reasons, reputable company and they have earned their reputation.
Old Jun 7, 2006 | 11:35 PM
brian's Avatar
i wouldn't trust those ebay ones...i dont think anyone has ever tried which is why you can't find it on this website. why don't you be our guinea pig!
Old Jun 7, 2006 | 11:57 PM
jwaggz82's Avatar
if you are looking for simplicity go w/ the TRD - I went with the TWM because it was shorter and shorter throws ... I like it a lot.
Old Jun 7, 2006 | 11:58 PM
brian's Avatar
i enjoy my creative compacts ss, $70 with **** can't be beat
Old Jun 8, 2006 | 12:04 AM
jwaggz82's Avatar
Im getting tired of my shift ****.... anybody know of a better shift **** then the one i already have here:
Old Jun 8, 2006 | 12:09 AM
uhh. better shift ****, you mean?
i have the TWM (Bombshell)
Old Jun 8, 2006 | 12:11 AM
jwaggz82's Avatar
yes - i edited my post before yours to reflect the change in txt.
NonStopTuning
Jun 29, 2015 07:42 PM
disaster06
Feb 3, 2015 08:50 PM
disaster06
Dec 26, 2014 03:00 PM
disaster06
Dec 4, 2014 07:05 PM
gularti
Dec 4, 2014 01:21 PM
