Please help me decide on sound system.(revised)
Old Jun 15, 2006 | 05:18 AM
srmfball's Avatar
Default Please help me decide on sound system.(revised)
These is the system I was thinking about putting in my car please feel free to comment about what you like or dont like so I can change it accordingly.(I havnt orderd any of it yet)
Headunit- Alpine CDA-9857
Speaker amp- JL 300/4
Front Speakers- eDi6500s
Back Speakers- Some kind of coaxil down the road (back not that important to me)
Sub amp- JL 1000/1
Sub- JL 12W7 ported enclosure
Capicator- Not sure but some kind.
What do you guys think? What speakers do you think? I will be having this done professionally at tweeter.
-Thanks
steve
Old Jun 15, 2006 | 05:38 AM
05FMtC's Avatar
get the jl vr650 csi comps and the jl vr650 cxi coaxials in the back. you wont be dissapointed.
Old Jun 15, 2006 | 07:11 AM
SkaTG2k3's Avatar
Defined3
i am not a big fan of JL speakers... but the tone is what you are really looking for... the subs are great! there is something to be said for uniformity though... I went with type Rs all the way around, but I hate the amps! i would have bought infinity kappas if i had the money and did not get a discount on alpine
Old Jun 15, 2006 | 11:25 AM
SCI_TC_GUY's Avatar
I'd suggest springing for components up front... since you're looking in to the top of the line JL sub, why not spend a little extra cash and get top of the line components... get the ZR650-CSi components up front and NOTHING in the rear... take all your soundstage and put it up front where it should be... alot of SQ competition vehicles use only 1 component set up front to give maximum imaging and staging the simplest way..
Old Jun 15, 2006 | 02:43 PM
srmfball's Avatar
If I were to go with the components in the front where would you guys reccomend putting the tweeters? I was also considering Type R's if i didnt go with JL. So what do you guys think Type R's or ZR650-CSi's.
Old Jun 15, 2006 | 02:53 PM
Jake_tC's Avatar
you can put the tweeters in the stock tweeter location. heh
and if they don't fit, cut it and make space
Old Jun 15, 2006 | 02:58 PM
SCI_TC_GUY's Avatar
I assume you have a tC, since this is in the tC section... I'd suggest just using the factory locations... my JL VR650-CSi components are in factory locations and it has decent imaging/staging... if you wanted to do something more custom, having custom fiberglass kick panels would be flippin sweet..... or a little more extreme would be the XR 3way components with the mid in the door or kickpanel and the 3" and tweeter in fiberglass dash pod in the far corners...
Old Jun 15, 2006 | 02:59 PM
srmfball's Avatar
So do you guys think I should just leave the rears stock or should i put some coaxil speakers in there?
Old Jun 15, 2006 | 03:03 PM
SCI_TC_GUY's Avatar
I have stock rears.... depends on what you're looking for... IMO, I think a car with no extra rear-fill sounds the best... I don't even hear my rear speakers at all... but really it's up to you.... If you do want rear coax's, get the same model as the fronts (example: XR650CSi up front with XR650-CXi in rear)
Old Jun 15, 2006 | 03:17 PM
srmfball's Avatar
Do you guys think the ZR650-CSis are worth the 500 bucks more than the Type Rs?
Old Jun 15, 2006 | 03:24 PM
SCI_TC_GUY's Avatar
Don't know... haven't heard the ZR's....but I've heard they're supposed to be badass... sending you a PM
Old Jun 15, 2006 | 08:22 PM
nodsetse's Avatar
I agree there's no need for rear-fill speakers at all. For those that want them, I suggest not spending anything more, the stock rear speakers will suffice. For SQ competitors that do use them, they almost always limit the response to <2kHz, and ensure the amplitude is at least 6 to 9dB less than that of the front speakers. Placing tweeters in the rear and/or running the mids at >2kHz can ruin your front soundstage by sometimes causing some portion of the program material to sound like it's coming from behind you, when it's not intended to do so.
Now if you plan on eventually watching movies in the car and want to do 5.1 audio in the car, what I stated above does not apply. In that case you would definitely want rear speakers, and if not exactly the same model as the front, then one that provides close to the same sound ("timbre"), just as should be done for home theater systems. People often use a given comapny's component set up front in this scenario, with the equivalent coaxial model in the rear.
evolving_machine
Oct 21, 2023 01:16 PM
2CTC
Sep 12, 2015 11:33 AM
djcezile
Apr 23, 2015 06:46 PM
SuBSiN
Mar 13, 2015 04:02 AM
corbmonster
Jan 24, 2015 05:22 PM
