czyker13
06-16-2006, 04:02 AM
Which electronic flasher should be used when replacing the turn signal bulbs with LEDs; CF13JL-02 (Japanese) or CF18-08 (Newer Toyotas)? And is this the best route to go?
http://www.superbrightleds.com/tail-brake-turn.html
Finally, if I replace the parking lights, do I need to add a 25 Ohm, 25 Watt Load Resistor to prevent bulb-out indicators?
Thanks
noservice2001
12-18-2006, 11:50 PM
http://autolumination.com/equalizers.htm
yes, better than load equilizers which can get too hot and burn things....
if u use a flasher, u don't need load resistors (well autolumination told me this) as well since the flasher should take care of that... have u tried it yet?
i'm trying to figure out where the clicking is comming from.... where do you put the equilizer in an xB?
is it under the hood or under the steering column?
chrischoi
12-19-2006, 12:16 AM
they try to say that every bulb is scientifically engineered. look at the pictures.. :rofl: i beg to differ.
SquallLHeart
12-19-2006, 01:12 AM
CF18-08
and there's no bulb-out thing for parking lights
i installed the cf18-08 flasher but now my signal lights don't work when i hit the lock button. the signals do work from the switches tho. is it a defective flasher?
