stock tweeter location
Tweeter is behind... well the tweeter grill.. You need to pry off the panel where the large handle is (with the silver circle trim) and there you will find 2 scews. Loosen those. Then if you look closely you will see a panel where your door handle is... use a flathead with tape and pop that open and loosen the screw... then just pry the door panel off and disconnect the wire harness.....
darkshadowofxdeath
Dec 3, 2014 06:59 PM
