Amp has no power, remote wire t-tapped on right wire
Old Jun 29, 2006 | 03:16 PM
Snowsk5054's Avatar
Default Amp has no power, remote wire t-tapped on right wire
My amp isnt getting power, blew a fuse yesterday, put a new fuse in, didnt blow the fuse this time, and still no power to my amp.
I t-tapped the remote wire into the gray wire, which is supposedly the ignition wire.
I did this right, right?
Any help would be appreciated.
Old Jun 29, 2006 | 03:19 PM
Neothin's Avatar
did you use a test light to see if that grey wire actually does go live when the car is turned on?
double check your splices?
maybe use a conventional splice instead of a t-tap. i've never been good with those things :-P
Old Jun 29, 2006 | 03:29 PM
Snowsk5054's Avatar
I double checked my splices, because thats what I thought it was, so I peeled back some rubber, and put a new t-tap on. Still no power.
I am gonna go out and check it with a test light in a minute.
Old Jun 29, 2006 | 03:39 PM
Snowsk5054's Avatar
I just tested it....I am getting 003 DCV at the amp from the remote wire, and 014 DCV at the area it is spliced.
Now I am confused.
Old Jun 29, 2006 | 04:09 PM
Fhe1079's Avatar
Rerun a new wire to the amp and check the other wire you removed for a pinched wire. Sounds to me like you have a crushed wire on you hands. After you run it to the amp... check the wire again before you connect it to the amp.
Good Luck.
Old Jun 29, 2006 | 04:10 PM
Neothin's Avatar
yep, sounds like a couple of the stands in the wire broke somewhere and it's restricitng the power from getting through.
rerun that wire
Old Jun 29, 2006 | 04:14 PM
mplex2000's Avatar
If the fuse blew you either grounded the lead wire at some point or it's taking too much load. I would replace the wire, if that doesn't help, choose a new wire to tap. Also, you ought to solder it, those tap connectors don't work well.
Old Jun 29, 2006 | 06:09 PM
JocoJef's Avatar
Did you just put this system in again? If everything is getting power (remote, powerwire), I would check the ground
Old Jun 30, 2006 | 03:23 AM
Snowsk5054's Avatar
I got a new fuse today, and the guy that I got it from said that it wasnt a big deal if I blew a fuse, because if a fuse from the previous installment is used on a new car, its gonna blow. He said it happened to him all the time.
Turns out it was the ground. I had it bolted to what I thought was metal, and it wasnt. So I hooked it to another spot, and bam. It works now.
Dont think I like it though, I think I am gonna take it out maybe.
Have you noticed that the converter kinda drains out your rear speakers...thats the speakers I connected the converter to. I think mine is draining the rear speakers.....idk.
Old Jun 30, 2006 | 07:20 PM
JocoJef's Avatar
I am the man
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
streetracerr
Jul 11, 2015 09:52 PM
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
randode
44
Jun 29, 2004 04:19 PM
oj411
Dec 25, 2003 01:31 AM
