Vent Shades/Visors..
Old Jun 30, 2006 | 05:09 AM
stitch76's Avatar
Default Vent Shades/Visors..
Hey Guy's And Gal's,
Thanks for all the input on the fog lights. Now We are trying to get the ventshades for the doors. Seems Autovent shades are the only ones I can Come up with.
The front ones don't fit because of the tab on window seal, and the back one are a shade too long for in channel.
But we can put both outside tabs out the window with double sided tape and they would work. Any body else having trouble or have gotten some that work, and from where?
Any help would greatly be appreciated.
Sitch76
_____
Old Jun 30, 2006 | 05:28 AM
Gaps720's Avatar
E'SAMs from japan and the E'SAM copies from m2 motoring are about the only way to go... they look and fit fantastic.
Old Jun 30, 2006 | 07:07 AM
OldYeller's Avatar
Got my E'sams from http://www.newscionparts.com/index.php
The copies from m2 motoring look identical except for the hooks.
Old Jun 30, 2006 | 09:49 AM
redfins's Avatar
Weathertec Great Proudct ...The Tab On The Front Can Be Moved To Fit The Visor
Old Jun 30, 2006 | 10:50 AM
dgHotLava's Avatar
weather techs are the best fit i found...
and Wades look about the same as weathertechs but half the price....
Old Jun 30, 2006 | 10:51 AM
dgHotLava's Avatar
230 for esams
or 80 for weathertechs
or 45 for wades.
you pick.
Old Jun 30, 2006 | 11:58 AM
pooder's Avatar
How Do I Move The Tab? I assume (yeah, I know what happens when I a$$-u-me ;^) you mean the tab on the window frame . . . right?
Old Jun 30, 2006 | 12:51 PM
Jhhnn's Avatar
I bought Wades from this vendor-
http://stores.ebay.com/Truck-Accessory-Depot
They fit fine, if a little tight on the rears. They've only been in for a couple of weeks, so we'll see how they hold up-
Old Jun 30, 2006 | 01:35 PM
TheRealBoxster's Avatar
Default tab move
The tabs are glued down. I carefuly forced them up and worked a thin flat screwdriver underneath to lossen the glue. I then eyed up the tab slot on the ventshade then made a small reference mark on the car where I should reinstall the tabs. Then I lifted the rubber molding and wiggled/slid them in. I havent had any problems. No leaking or anything like that.
Old Jun 30, 2006 | 01:49 PM
dgHotLava's Avatar
they are not glued down.
they are held in place with double sided tape. pinch the inside part and the outside part together and pull out of the window channel. (it will pull the rubber window molding out too)
you simple lift it up, move it, and put it back onto the tape...
yes, make a referance mark so you know where it needs to go.
Old Jun 30, 2006 | 03:10 PM
I didnt slide the tab down because - I didnt want to seperate more molding than I had to. It wasnt too bad to slide it in.
Old Jun 30, 2006 | 08:12 PM
saylor's Avatar
weathertech FTW.
I bought the bug shield and the dark vents for 2 bills shipped. The front ventshades trailing edge cracked on the very end-edge when I was installing them - they were molded slightly (quarter inch) too long I guess,, anyways the expedited a new set to me for free - had them like in 2 days or so.
Weathertech is the shiz - they'll do you right.
- Saylor
Old Jun 30, 2006 | 08:46 PM
stitch76's Avatar
Default ventshades/visors
Thanks for all the info on the ventshades. We will check them out .
Ya'll have a GReat 4th of July.
Thanks Again
Stitch76[/b]
Old Jun 30, 2006 | 09:09 PM
PhillyCamoBox's Avatar
i got wades had a little trouble with the front passanger. wound up losing a inch or two off the bottom but the rear view hides it... plus its good for ashing a joint... any how the others went in like butter. they are inchannel also by the way..
Old Jul 2, 2006 | 02:07 AM
x-ray_Bravo's Avatar
Do in-channel visors require tape or glue to hold them in place, or do they just stick in and stay?
Old Jul 2, 2006 | 02:17 AM
dgHotLava's Avatar
front in channel do not require anything to stay put...there size and ahape do the job well.
the rears use a small bit of 2 sided tape to keep them there when you first put them in.
although i never used the tape on mine and they are still fine after 2 yaers....
Old Jul 2, 2006 | 04:27 AM
That's good to know. I would rather not use tape, if I can get away from it.
Old Jul 2, 2006 | 05:23 AM
hotbox05's Avatar
WADE are the best by far. thicker , better fit , better look , great price. about 54.00 shipped off ebay!!! much better then ventshades , weathertech or imo esams/fake esams. i hate their look and price is why not their quality.
Old Jul 2, 2006 | 06:13 AM
Are they in-channel or out-of-channel? Link?
Old Jul 2, 2006 | 06:24 AM
hawaiiguy's Avatar
Wade brand visors are 'in channel' ...
for the price, very good looks and installation was quite easy...
