alarm question: put a ground trigger on the door handle?
Old Jun 30, 2006 | 02:08 PM
xnevergiveinx's Avatar
Default alarm question: put a ground trigger on the door handle?
i have an alarm pro ca-330 factory add on alarm. it works essentially the same as the alarm you would purchase from the dealer, it also uses the stock key for arm/disarm
what i would like to do is figure out a way that i can have a ground trigger when someone lifts the door handle. my friends 95 grand am used to turn on the door light when you lifted the door handle (even when it was locked) and that worked really well for his alarm
i'm not sure how i would go about doing this though, i think i would have to fab up some sort of switch and bracket on the inside of the door. i'll take off the door later on today and check it out
ideas?
Old Jun 30, 2006 | 06:53 PM
i took off the door today, it doesn't look like it would be anything easy
i might be able to fab something up that would hold this switch:
it might turn out to be too much work though
TotalChaos
13
Feb 4, 2015 10:24 PM
toyotaisme
Jan 10, 2015 10:24 PM
wizzlexB
Dec 27, 2014 04:06 AM
boxzila
34
Jan 12, 2004 03:27 AM
racingtoys
Dec 4, 2003 10:34 PM
