Cruising Speed for Optimal Highway Mileage
Old Jul 7, 2006 | 02:14 PM
EDG's Avatar
EDG
Default Cruising Speed for Optimal Highway Mileage
Does anyone know the highway crusing speed used to produce optimal mileage results with a Scion tC?
Old Jul 7, 2006 | 02:25 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
keep RPMs down, key factor
Old Jul 7, 2006 | 03:43 PM
farberio's Avatar
Probably 50...thats about right before you start the power band.
50-55
Maybe a little higher for autos.
Old Jul 7, 2006 | 03:45 PM
engifineer's Avatar
^^ exactly. And even more important is to run at a steady speed and accellerate smoothly. When travelling to my home town I set the cruise at about 80 mph for about 90% of the 9.5 hour drive. I see between 28 - 32 mpg every time, including AC on, AC off, winter, summer, etc.
Old Jul 7, 2006 | 03:56 PM
MJVsTC's Avatar
Is your tC Auto engifineer?
Old Jul 7, 2006 | 03:59 PM
dgHotLava's Avatar
best speed to go is just around peak tq of the motor.
Old Jul 7, 2006 | 04:44 PM
engifineer's Avatar
Mine is a 5 spd. I was saying exactly to the the post above the one I pointed to, the other guy posted in between.. so it made mine sound a bit confusing
Old Jul 7, 2006 | 05:12 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
i thought you were agreeing with mine
but was confused
Old Jul 7, 2006 | 06:11 PM
engifineer's Avatar
I was... but managed to post slow and confuse everyone :D
Old Jul 7, 2006 | 06:28 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
ish happens
we got the jist of it
Old Jul 11, 2006 | 04:04 PM
ndnbolla's Avatar
So let me give you a situation...
Auto, which is better for the MPG...
65-70 mph/ ~2500 rpm
or
80 mph/ ~3k rpm
I have 80 miles of hwy commute everyday and I would rather do the quicker option but if I got an extra 80 miles if I went ~65, I wouldn't mind doing it.
Old Jul 11, 2006 | 04:28 PM
jon-w9's Avatar
Obviously the slower speeds will be better for MPG.
TO really compare I guess you should fill up, do a trip at 80, and calculate the MPG, and repeat for the other speeds.
My guess would be the slower is better, but it won't make a ton of difference.
Old Jul 11, 2006 | 08:55 PM
Jon's Avatar
Jon
Moderator
Moderator
I try to keep it under 3k RPM when on long trips. In the city, I rarely use cruise control.
Old Jul 11, 2006 | 09:02 PM
rosskoss's Avatar
Depends if you have auto or manual.
On both, best to keep rpms low so I do about 70 on manual (still over 3000 rpm).
The auto is geared much better for highway cruising so I would go a lot faster on without worrying about mileage.
Old Jul 11, 2006 | 09:11 PM
tcturboscion's Avatar
I haven't found there to be a big difference in fuel economy while on the highway at constant speed. I have the 5spd and have done the same trip at 65 and 80 and both times got 31.2mpg. Both times I had the AC on with about the same weather. I would estimate there that there is only about 1mpg at most to be saved by keeping a lower speed.
Old Jul 11, 2006 | 09:28 PM
ricktoyota73's Avatar
Old Jul 12, 2006 | 04:53 AM
magyver's Avatar
what rpm doyou guys run at 70mph? im at 3100 w/ the sc... curious if mods change that...
Old Jul 12, 2006 | 07:42 AM
mandangalo's Avatar
only if your mods include changing out your gearing, or if your tire size is different from stock.
Old Jul 13, 2006 | 02:03 PM
GetCaughtDead's Avatar
easy way to find out... get a ScanGuage II !
Old Jul 13, 2006 | 08:04 PM
tml057's Avatar
First part:
http://youtube.com/watch?v=URI80bckL...=Audi%20diesel
Second part:
http://youtube.com/watch?v=qmAK4OB9R...les%20part%202
You guys could learn a couple of tips to save on gas from this video.
